Old 10-07-2017, 09:52 AM   #1
Mollysdad's Avatar
12v. path?
I have a 2017 26U.
I plan on installing a battery disconnect, like the Perko units that are popular on boats. "On/Off".
I'd like it to be inside by the door, so one could reach it to turn on or off. Luckily, there's the big seating area right there.
But, does the main positive go under the floor to the converter? I won't drill a hole in the body, but I would follow a wire already going. Sadly, there doesn't seem to be room in the battery box to add a large switch, and I want it out of the weather and tire spray.
Alternate ideas?
Old 10-07-2017, 09:59 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
https://www.amazon.com/Post-Battery-.../dp/B001N729FS
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-07-2017, 10:28 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by Al and Missy View Post
Or this can work too. It can be mounted close to the battery, and remotely controlled with a momentary switch.
Cole Hersee 24200 Latching Solenoid https://www.amazon.com/dp/B001FQMZQU..._Iaq2zbR5KNAMF
Old 10-07-2017, 10:31 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
This is pretty cool too.
Car Wireless Remote Control Battery Switch Disconnect Latching Relay Anti-theft, E-KYLIN DC 12V Electromagnetic Solenoid Valve Terminal Master Kill System https://www.amazon.com/dp/B01IVNE9MC..._qeq2zbE69PE85
Old 10-07-2017, 10:54 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I believe you will find that there is more than one cable to the battery. Of course it's AS so one can never be 100% sure The inverter often seems to get a dedicated wire.
Old 10-07-2017, 11:05 AM   #6
Mollysdad's Avatar
Thanks, I kinda expected that, but figured I could have one large cable to the switch and all the smaller one's attached to whatever post I provide for the other side. BTW, after scouring YouTube it seems the consensus is to NEVER put the switch into the + path, but to use the -.
(I wouldn't have done that, but I will)
The AS is not at the house, so I need to check the batteries when I go to load stuff in it tomorrow.
When I looked at the dealership, I saw two Interstate Batteries in the box and didn't take a photo. Google shows more than one cable in their images.
Have you actually used that successfully? I've seen them on Google. Here, they don't have to carry huge current like a car would.
12v
In the path of Sandy monkeypants Off Topic Forum 61 01-18-2013 09:33 AM
Off the beaten path Keewatin 2009-2015 Flying Cloud 1 07-23-2012 01:32 AM
'72 running lights wiring path needed captainhoek Lights - Interior & Exterior 4 05-29-2012 09:11 PM
Which Path for Axles and Brakes? JimGolden Axles 9 02-17-2006 06:36 PM
For folks fleeing path of Hurricane Rita... bake315 Our Community 4 09-23-2005 02:08 PM
