Old 06-07-2007, 10:06 AM   #1
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
12V Electrical Questions
Hi Folks,
I'm getting ready to install my new Parallax 4400 converter and 6V Lifeline battery bank in my 1965 Overlander. Thanks to all the good advice here, I've been able to locate all the critial components of the system however, I wanted to double check before I begin, is this the "Low Voltage Distribution Panel" that is referred to in the installation literature?
Airstream 65 is offline   Reply With Quote
Old 06-07-2007, 11:23 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Sure looks like one.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-07-2007, 01:24 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Yup. Although I personally think calling it that is charitable at best.
Old 06-07-2007, 03:38 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
What you have there are 3 cicruit brakers and fused feed lines. Check the rating on the circuit brakers and make sure the fuses are no more than 80% of the total of the circuit berakers. If the wire going into the brakers is #12 than the fuses should be no more than 20 amps. Can't tell from the pictures as to the wire size.
The red line should be the hot line and the white line is the ground.
2004 Excursion 4x4
Old 06-07-2007, 04:24 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Step 2?
... I wanted to double check before I begin, is this the "Low Voltage Distribution Panel" that is referred to in the installation literature?
Yes it is. While it may not look like much, it is all that is needed for the task at hand. My '67's LVP is arranged a little bit different but it does the same thing yours does.
Out of curiosity, now that you can cross that step off in the installation literature, what does the guide tell you to do next? i.e. cut a wire ... install adapter block ... ?
Tom
12v
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 08:20 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 03:04 PM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 02:14 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
