Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 10-25-2009, 07:17 AM   #1
Clyde-2's Avatar
Profile:  1972 27' Overlander
Bonita , Texas
12v Electrical Issues
Should the interior 12v lights dim and fluctuate as other lights are turned on.....when the battery is fully charged and plugged into shore power ? Sometimes the interior lights are a bit hesitant to come on and it takes a couple flips of the switch. Do I have a grounding problem ?
Link to my restoration blog:
http://www.airforums.com/forums/blog...7-clyde-2.html
Clyde-2 is offline   Reply With Quote
Old 10-25-2009, 07:29 AM   #2
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Cann't see why playing with the switch would help unless it's bad. Is this a new problem in a trailer you have been using or a trailer new to you?
SOFI Member
Over59 is offline   Reply With Quote
Old 10-25-2009, 07:42 AM   #3
Clyde-2's Avatar
Bonita , Texas
It's a "new to me" trailer as i bought it from my neighbor, but it has been sitting for the past 25 years and all of the connections, etc are dirty. Have cleaned the fuse contacts in the Univolt and on the battery terminals. I think it's a ground issue but not 100% sure.
Old 10-25-2009, 08:13 AM   #4
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
bet that univolt is bad.... the switch is for sure. always remember that 90% of 12 volt issues are grounding issue though. I would replace that obsolete univolt with a new intellipower. also the switch to be certain.
62overlander is offline   Reply With Quote
Old 10-25-2009, 09:01 AM   #5
Profile:  1976 25' Caravanner
Campton , New Hampshire
I had this problem recently and it was the switch in the front overhead light. Could also be a very old battery. Try taking the battery out and test the lights on just the univolt.
ticki2 is offline   Reply With Quote
Old 10-25-2009, 09:12 AM   #6
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
The switches in the overhead lights tend to build up corrosion on the contacts. Take them apart carefully as there are one or 2 very small parts. Clean the metal contacts with emery cloth. Also clean out the light sockets.
Pay no attention to the man behind the curtain- WoZ
70s 12V electrical question Zeppelinium Lights - Interior & Exterior 3 06-17-2009 10:34 PM
Adding interior 12v electrical connections Lumatic Electrical - Systems, Generators, Batteries & Solar 1 11-19-2007 08:20 AM
2005 CCD electrical issues ablaze Electrical - Systems, Generators, Batteries & Solar 7 10-29-2007 06:57 PM
12V Electrical Questions Airstream 65 Batteries, Univolts, Converters & Inverters 4 06-07-2007 04:24 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 11:58 AM
