Old 05-14-2016, 02:26 PM   #1
Bend , Oregon
12V battery health
What's the appropriate way to test a 3-4 year old 12V battery to see if it needs replacement? Not having any problems with it but would like to know its 'health'. Use a hydrometer?
chaeha is offline   Reply With Quote
Old 05-14-2016, 02:36 PM   #2
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Battery reliability
Take it to an Interstate dealer and they will check and confirm for little or no cost to you. A hygrometer is about $8 and your batteries should never go below 11.5 v.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 05-15-2016, 11:32 AM   #3
richw46's Avatar
Lexington , Kentucky
If the battery is not a sealed battery you can use a hydrometer. The ones in local parts stores are small and difficult to read. I got a nice one from Amazon for $10 a couple years ago. You used to be able to buy these anywhere but now they seem to have those pencil sized ones. Bigger is better, I say. The hydrometer will tell you if you have a dead or weak cell and the state of the other cells too.
http://www.amazon.com/OTC-4619-Profe...ilpage_o00_s00
If the battery is sealed you can't get a hydrometer in to check the specific gravity. At Harbor Freight I got a battery load tester for $22. http://www.harborfreight.com/100-amp...ter-61747.html I've had it for about a year, check my batteries periodically. It's cheap but does the job. There have been some complaints about it wearing out in a short time but for $22 and over a year now, no complaints from me
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-05-2017, 08:15 PM   #4
Bend , Oregon
12V battery health
Fully charged my two 12V batteries wired on parallel using a trickle charger.
Unhooked and charger and the voltage reading was '12.6' 24 hours later.
8 days later the reading is '12.1'.
This pretty normal? Or a sign an aging batteries?
I tested all the cells using a hygrometer and they all registered in the 'good' range.
Old 04-05-2017, 09:08 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Run them...
Old 04-05-2017, 09:49 PM   #6
Breckenridge , Colorado
If you have a local shop, have them test it. Usually no cost. Deep cycle batteries test differently than starting batteries but they can usually tell if there is trouble ahead. Same with hydrometer - useful tool, but won't tell you the whole story, but it can give you some good clues.
-Dave
snow is offline   Reply With Quote
Old 04-06-2017, 12:21 AM   #7
Long Island , New York
Are these the same batteries you asked about back in the OP in May 2016? And are they installed in your AS and hooked up, with the voltage readings above taken on your monitor panel? In my lay opinion you should have gotten better than 12.6 after 24 hours, and better than 12.1 8 days later.
You may have phantom loads drawing down your batteries, other than the propane detector. Standard culprits include the stereo/radio/sub-woofer running in a stand-by mode in the background.
When you "unhooked" did you also put the Use/Store switch in the Store mode?
Have your batteries ever been discharged with voltage readings below 12 volts? And the year labeled on the batteries is . . .
Lots of possible variables, so please give more details.
You may need new batteries for peace of mind for the upcoming summer, in my opinion.
Good luck!
PS -- After fully charging our batteries, we can go 7-10 days in Store mode, before reaching 12.5 volts -- or about 90% of capacity. [Below 12.1 volts indicates <50%.]
12v
health effects of antifreeze? jeff&jess Winterizing, Storage, Carports & Covers 16 12-03-2006 10:20 AM
Computer Health -- PC owners CanoeStream Off Topic Forum 8 11-20-2006 04:06 PM
Timers and Battery Health rfield54 Batteries, Univolts, Converters & Inverters 12 10-01-2004 04:51 PM
Battery health with 110 volts going full time Mark Wiltrakis Batteries, Univolts, Converters & Inverters 11 03-15-2004 09:14 PM
Fulltime, Way before 65, Health Insurance DreamStream Off Topic Forum 1 03-09-2004 02:32 PM
