Old 11-25-2011, 11:21 AM   #1
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
120v 20amp GFCI keeps blowing
I could use a little help. I am camping right now and the GFCI keeps blowing. I have narrowed it down to the intelipower 9270. But I am not sure why. Is the intelipower bad? I took out all the fuses leading out of the intelipower so I know it is not the 12 volt system causing the isssue. I am getting the extra juice out if the intelipower so I think it is working right. The breaker does not blow when the intelipower is unplugged. The time it takes for the breaker to blow with it plugged in changes from instantly to 30-40 minutes with the intelipower plugged in.
I am at a campground hit bad by huricane Irene so could it be the shorepower causing this?
I started to think it was the 32 year old gfci breaker that went bad. I bought a replacment (still have an hours drive to get back to try) but still not sure what else it can be. I think the grounds are good because it has been working fine for the past 3 years.
Any thoughts would be greatly appreciated.
nick6930 is offline   Reply With Quote
Old 11-25-2011, 11:40 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
A correctly working GFCI trips when the current leaving on the hot wire is not exactly balanced by that coming back in on the neutral - in other words, when there is some current (perhaps only a milliamp or two) from the hot wire to the ground - hence the name, Ground Fault Circuit Interruptor. More modern units may also trip when they sense an electrical arc, but that's not of interest here, I think.
They are known to go bad, and early ones were indeed quite easily tripped by electrical noise, etc. Sometimes they fail so as you notice (tripping all the time), sometimes they fail by not working, which is why the outlet versions have test buttons.
Because these units are quite sensitive, the various components should be grounded together carefully. In particular here, I'd make sure that the ground for the Intellipower is properly bonded as per instructions to the trailer ground.
If you have a DVM, make sure there's minimal resistance (with unit unpowered) between the ground connections on the trailer umbilical and the Intellipower.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-25-2011, 11:42 AM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Yes, there could be an intermitant connection between the campsite ground and neutral.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 11-25-2011, 02:08 PM   #4
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Thanks for the info. I just got back and found a loose ground (terrible ground setup, the PO used a screw in the inside skin) I tightened it and will see if it pops again. It has worked all summer with no issues just all of a sudden down here. So I am hoping that it is just a ground that became lose instead of the intellipower going bad.
Old 11-25-2011, 06:13 PM   #5
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Well it has been several hours and the breaker is holding. I am both glad and frustrated that it appears to be a ground. It was one of the first things I checked. But onlyby hand giggling. If I only got up and grabbed a screw driver.
If nothing else I have a $45 spare breaker. It would cost $20 in gas just to return it.
Thanks guys for your input. Reinforcing the ground issue was what made me go back and check for certain.
Blowing water pump fuse perryg114 Fresh Water Systems 3 10-04-2011 08:36 PM
New refrigerator 110 or 120V? Chlyman Electrical - Systems, Generators, Batteries & Solar 15 09-30-2011 10:41 AM
Remove a Dometic without blowing up or frying my person gronlampa Refrigerators 2 08-09-2011 09:43 PM
Keep blowing trailer light fuse on TV StreamRollin Lights - Interior & Exterior 8 07-09-2011 02:03 PM
Help! Im boondocking and fuses keep blowing AUTAILGATER Batteries, Univolts, Converters & Inverters 13 04-15-2011 02:10 PM
