Old 01-27-2013, 05:07 PM   #1
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
12 volt yes or no?
I have question about the 12v stuff. I have a 1961 Overlander. I don't know if any of the 12v stuff works or not. I do have the wires going into the battery box, so that's good. What are the advantages of 12v? I don't plan on camping without shore power so should I mess with it? I do have an inverter that I snatched out of my old pop up camper if I need it.
Cristobal is offline   Reply With Quote
Old 01-27-2013, 05:30 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
The following are 12 Volt in your Overlander:
1. All lights
2. Furnace
3. Water pump
4. Electric tongue jack if you have one
Even when camping with shore power (120 volt AC), the foregoing are 12 volt DC.
That's what the "converter" does. It coverts 120 volt AC to 12 volt DC. (An inverter is something else.)
Suggest you get quickly get up to speed on basic electricity. Lots of good reading material out there.
All the best!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-27-2013, 05:34 PM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
What about Trailer brakes, they run on 12v DC.
Ahab is offline   Reply With Quote
Old 01-27-2013, 05:34 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
If the wiring hasn't been modified since your trailer was manufactured, each of the lights and fan motors is set up to run on either 12v or shore power. The lights do this by having two bulbs -- one 12v and one 120v. The fan motors have a small transformer.
If that setup is still intact then you don't need to do anything with your 12v system unless you plan to use it -- everything could run off the 120v shore power directly.
Most Airstreamers find that having battery (12v) power available is helpful for short stops, loading, and unloading, even if there are no plans to camp without shore power.
Old 01-27-2013, 05:35 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
1. All lights
2. Furnace
3. Water pump
All the best!
Not in 1961.
Old 01-27-2013, 05:48 PM   #6
1988 32' Excella
Robbinsville , New Jersey
Well that is mostly from the TV, except the required by law breakaway switch.
Old 01-27-2013, 06:34 PM   #7
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
I mean't converter, not inverter.
Old 01-27-2013, 07:18 PM   #8
SteveH's Avatar
Common Sense , Texas
If you want a travel trailer, then yes to 12 VDC.
If you will be happy with a park model, then it doesn't matter.
Regards,
Steve
Old 01-27-2013, 09:21 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Despite the fact that you currently do not plan to ever be without shore power there might be times when you will not have shore power, even if it's just for a short time no by your choice. If it were me, I'd want to be able to run off 12v, too. It will also be a good thing if you were to decide to sell the rig.
TB & Greg and Abbey Schnauzer
#3954
Old 01-27-2013, 10:16 PM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
To expand on the Trailer Brake issue, mentioned above...
Most States require that trailers with brakes have a system to activate them in case the trailer becomes uncoupled from the Tow Vehicle on the road...
For all AS's equipped with electric activated brakes, the installed 12volt battery (s) in the trailer provides the current (through the break-a-way switch on the tongue) to activate your brakes - in case it parts with the tow vehicle...Ooooops
Even if you were to gut the trailer of all it's other 12 volt applications, you'll still need a 12 volt battery (of a size to provide enough current to apply the brakes) for the break-a-way circuit...
Happy trails...
Ray & Pat; Morada, CA
12 volt
