Old 06-06-2010, 06:27 PM   #1
Spring Hill , Florida
12 volt went out
The inlaws have been living in our Airstream while they build a new house. Father-in-law called tonight, said the 12 volt lights started going dimmer and dimmer and now don't work at all, but the 120 volt outlets and a/c work fine. The battery is 4+ years old.
Does the 12 volt system go out if the battery is bad? Or could this be a Univolt problem? Any advice would be greatly appreciated
dorfgog is offline   Reply With Quote
Old 06-06-2010, 07:46 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I'd start by charging the battery back up. The lights getting dimmer & dimmer was the charge leaving the battery. I does sound like you have a charging issue. Check the fuses. There are some fuses between the charger & battery. Can't offer much more help without more details. maybe photos?
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-06-2010, 07:49 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Make sure that there is power to the outlet the Univolt uses, too.
Vaughan
Old 06-06-2010, 09:44 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, check the charging system to see if it is working; And yes, a 4 year old battery can go bad. My batteries went bad in about 3 1/2 years since delivery. That made them about 4 years old since manufacture.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-14-2010, 09:27 PM   #5
Well, I got the battery tested and it wasn't holding a charge, so I replaced it. So far, so good. Also turns out a PO replaced the Univolt at some point with a Magne-Tek 3230, which does have a 3-stage battery charger, so unless this battery goes dead in the next few days I think the problem is solved. Thanks to all for your advice!
Old 06-15-2010, 12:27 PM   #6
Ottawa , ON
My Univolt is the original. There is no battery in my TT.
The lights all work.
:: swell spooky organ music ::
Old 06-15-2010, 12:41 PM   #7
You must have one of those optional cold fusion generators under the rear bed
Old 06-15-2010, 01:08 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
I'd do this with my '74 Argosy some when I was working on it -- the lights would run from the Univolt. Though I believe it was Inland Andy who said it was hard on the Univolt without the battery in the circuit. If a Univolt cries in the forest and there's nobody there to hear it....
Mebbe the much more advanced MagneTek won't operate the lights without a battery in-line.
You still may not know if the actual problem was the battery. I've got a fairly simple VOM and monitor my battery voltage when questions arise. Don't damage that new battery -- make sure you aren't in the habit of letting it get below 40-45%. State of charge charts apply to a battery that has rested for 6-8 hours.
Name:	state of charge.gif
5 meter Langford Nahanni
Old 06-15-2010, 01:36 PM   #9
1978 28' Ambassador
Savannah , Georgia
Have the same issue with my '78. Noticed lights got dimmer and dimmer. Battery recharged overnight. Battery is less than four months old. On control panel I had noticed the light above AC power was not working. Assumed LED was burned out. Checked the 4 amp fuse and it appears to be good. Did notice some corrosion on contacts for fuse. How to procede? Disconnect 120 volt/plug? Clean contacts? What is this 120 volt outlet univolt uses? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 06-18-2010, 08:32 PM   #10
Arrrrgh! The new battery discharged... I'll have to put a meter on the converter, but it sounds like it needs replacing. By the time we get everything fixed, we're not going to have any money left to take it out! Oh the joys of a vintage Airstream.
12 volt
12 Volt TV? aftermath Audio, Video & TV 29 09-17-2011 11:18 PM
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
