Old 02-01-2008, 07:36 AM   #1
1989 34.5' Airstream 345
Dimmitt , Texas
12 volt question
In my 1989 345 motorhome the 12 volt system starts losing power when we use it for about 2 days with the inverter charging the system. If I wait about 3 days with the inverter unplugged recharge the batteries and the system works great for about another 48 hours then the same problem. My Question is should I replace the batteries or look for another problem first.
Max
maxr is offline   Reply With Quote
Old 02-01-2008, 07:58 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Max
If you are talking about the onboard house system, either the inverter power is not getting to the batteries, or the inverter is not functioning.
Old 02-01-2008, 08:43 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Look for a bad connection. check all your grounds carefully.
Michelle TAC MT-0
Sarah, Snowball
Old 02-01-2008, 09:08 AM   #4
Images: 59
There are lots of things to check, like transfer switches, fuses, relays. If you want to start chasing down possible problems you'll need a good voltmeter and a schematic.
Otherwise take it to a dealer or Camping World. Don't start replacing stuff until you have a diagnosis, that's the most expensive method.
markdoane is online now   Reply With Quote
Old 02-01-2008, 10:27 AM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I agree with Terry. Teh symptoms indicate either the invertor is not working, or the energy it is producing is not making it to the batteries. A multi-meter and a little time should lead you to the problem in short order.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 02-01-2008, 11:15 AM   #6
2005 22' Interstate
Afton , Virginia
I'm Confused
Max
I'm not trying to be smart or anything, but, an inverter USES power from the batteries. A converter is the unit that CHARGES the batteries. From the description, I don't see where a problem exists; things appear normal to me.
Please explain further.
regards
herrgirdner is offline   Reply With Quote
Old 02-01-2008, 11:34 AM   #7
nangoff's Avatar
2004 28' International CCD
Franklin , Tennessee
Put a digital voltmeter across the batteries when plugged in when you expect to be charging. You should see 13.5 to 14 volts or so. (I'm sure this is nothing new to you). If your batteries have gone through a number of big discharges the batteries can be "surface charging" only and not capable of holding a charge; ie, they are bad. You coulds also have a cell in one battery bad which will cause the battery to heat up abnormally, Id feel the batteries for a difference in heat. Just some thoughts. GG
nangoff is offline   Reply With Quote
Old 02-01-2008, 12:24 PM   #8
Well Preserved
1993 21' Sovereign
regards
In his post, he did say the inverter was hooked up to charge the system. Probably a typo, they do sound similar, even if they perform opposite functions.
Old 02-01-2008, 12:50 PM   #9
Dimmitt , Texas
12 volt question converter
the converter would be correct taking 120vac to 12 vdc sorry about the confusion
Max
12 volt
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
12 Volt Question jwaldin Electrical - Systems, Generators, Batteries & Solar 11 02-03-2003 05:42 PM
