Old 06-15-2007, 12:13 PM   #1
1971 23' Safari
Beaverton , Oregon
12 volt ground for 71 Safari?
I'm trying to add an additional 12 volt circuit to connect to my new refrigerator. I have an open spot in the converter for another circuit and could easily run the wire to the fridge, but I can't seem to find where the ground should go to. Is there a common 12 volt ground and where is it? Or do I just connect the ground lead from the fridge directly to the frame?
Sorry if this topic has been beaten to death, but I couldn't locate anything on it in the threads using the search tools.
Thanks for your help!
Pete
rrpranch is offline   Reply With Quote
Old 06-16-2007, 05:49 PM   #2
1971 23' Safari
Beaverton , Oregon
Ok, so I figured out the 12 volt circuit question.
But during installation of the circuit I noticed that there is no fuse or circuit breaker on the positive lead from the batteries to the converter.
I'd like to install a reset-able breaker instead of a fuse. Does anyone know what size I will need?
Thanks!
Pete
Old 06-16-2007, 06:38 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
About 50 amps.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-16-2007, 07:56 PM   #4
1971 23' Safari
Beaverton , Oregon
50 amps! Wow, that's mighty beefy. I had no idea the converter could draw that much juice.
Thanks for your help! Time to go shopping.
Pete
Old 06-16-2007, 09:11 PM   #5
Images: 59
The converter draws 120Vac (less than 15 amps) and puts out anywhere from 45 to 80 amps of 12V, depending on your converter. So the converter isn't drawing that much juice, it's putting it out to the battery and lights.
50 amps is the standard circuit breaker used between the battery and converter.
Old 06-16-2007, 09:20 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It is also the standard size fuse for ground on our trailers.
Old 06-17-2007, 01:22 AM   #7
1971 23' Safari
Beaverton , Oregon
Thanks for that info guys.
I also noticed that the P.O. didn't connect the external ground on the converter box. Is that an optional connection or should I do some additional wiring? Should that be wired to the shell or the frame?
Workin' on this trailer is like givin' a pig a pancake!
Pete
Old 06-17-2007, 06:14 AM   #8
Images: 59
It's not optional. I don't know the technical reason, but it's important enough that the Natl. Elec. Code requires it, and makes a point of calling it out.
Old 06-17-2007, 06:25 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Ground the external connection of the converter to the frame of the trailer. You can also add it to your ground buss if it is connected to the frame .
It is there (mechanical ground vs. the nuetral-electrical ground) as a safety to dissipate the charge in the event of a malfunction or overload in the converter.
Old 06-17-2007, 01:19 PM   #10
1971 23' Safari
Beaverton , Oregon
Thumbs up
Thanks Mark & Lew. I'm on it. Don't you just love P.O.'s!!
Pete
Old 06-17-2007, 01:38 PM   #11
1971 23' Safari
Beaverton , Oregon
I hate to open up a can of worms, but what do you guys think of the current power converter I have? It's a Parallax Power Components Model 3230. It's a 30 amp converter/charger. I'm not sure what it's battery charging characteristics are. Anyhow, is this adequate for a 23' Safari or should I be thinking of replacing it?
Thanks!
Pete
The six week tour of the Rockies begins July 21st!
Old 06-17-2007, 02:46 PM   #12
Well Preserved
1993 21' Sovereign
Thanks!
Pete
As long as it's got electronic voltage control, it should be fine. Most Univolts were 40 amp, I would rather have a 10 amp less converter that is more reliable, like the Parallax.
Old 06-17-2007, 04:25 PM   #13
1971 23' Safari
Beaverton , Oregon
Whew, that's a relief! It seems to be doing a good job so far.
I made a little error though. I know you're supposed to keep the water level up on the batteries (I have have two 6 V golf cart batteries hooked in series). So naturally, I checked the levels and topped them off... With tap water. Oops! The bad thing is, I know better than that. It was a haste makes waste moment. The question is: Are my batteries ruined and is there a way to check?
Thanks again
Pete
Old 06-17-2007, 05:11 PM   #14
Well Preserved
1993 21' Sovereign
Thanks again
Pete
The "correct" thing to use is distilled water, but I have used tap water many times with no ill effect...I've even used it in the battery on occasion.
12 volt
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
Looking for ideas on a sofabed for my Safari Scotti General Interior Topics 0 09-03-2002 01:45 PM
