Old 02-12-2011, 03:37 PM   #1
1977 25' Tradewind
Prince George , Virginia
12 volt fuses
We have a 1978 Airstream Tradewind and it has a new battery but it will only last a day before we have to charge it again..My question is just where is the inverter/ converter..it has a fuse box but does it also have a inverter converter? the fuse box is behind the sofa and also does anyone have apicture of this fuse box,our book got wet(before we bought it) and the page is all messed up so that I can not tell what goes where..we are planning on taking the old sofa out and replacing it with something else and also so that we can get to the fuse box..Thank you in advance for any informatio that you have..
Thanks, Nancy
bobsbabe2@aol.com
bobsbabe2 is offline   Reply With Quote
Old 02-12-2011, 05:01 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Do you know where the 120 volt Ac power panel is in your trailer?
Do you know where the battery is? the converter may be close to the battery. If it is a rear bath it may be like my Argosy and be in a closet in or near the bath.
If the converter is running and it is original you should here it humming. But if the AC power is shut off to it. It won't charge the battery. There are also fuses in the battery charge circuit.
Old 02-12-2011, 05:07 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Nancy,
TG Twinkie has a good set of questions. A little more info about your trailer would help.
There are photos of the DC fuse panel, the batteries, and the Univolt (and replacement Inteli-Power) with the sofa removed in my 1983 Excella here: http://www.airforums.com/forums/f449...0-a-57567.html. Hopefully there is enough similarity to help you out.
My Excella is a center bath, rear bedroom. The AC breaker box is in the closet across the hall from the bathroom on the exterior wall.
Good luck.
Vaughan
vswingfield is online now   Reply With Quote
Old 02-12-2011, 06:30 PM   #4
1977 25' Tradewind
I have a rear bath and inside the closet is an AC breaker box ..It is ok and that is all we can use until I recharge the battery again . The battery is on the outside on a tray that u pull out after you unlock the door..nothing works on 12 volt until I recharge the battery again..The Airstream is setup on a camping site..we have to charge the battery so that I can tell when we need to empty the holding tanks and it will only light up using 12 volts..Hope this helps
12 volt
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Confused about Converters DanielB Batteries, Univolts, Converters & Inverters 11 02-12-2011 08:32 AM
1958 Porch Light mello mike Lights - Interior & Exterior 24 02-02-2011 01:50 PM
How a 15 minute job can ruin a whole weekend DougZ Lights - Interior & Exterior 5 01-23-2011 01:09 PM
Lights work on battery, but not 120 volt! Andreasen Batteries, Univolts, Converters & Inverters 8 01-22-2011 05:17 PM
