Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 10-08-2009, 11:24 AM   #1
stain's Avatar
Profile:  1959 26' Overlander
calgary , Alberta
12 v wire ???
It is getting cold !!! first layer of insulation is almost done in the walls ... my question is can I use solid wire instead of stranded ??? for 12v I have a roll of 12 gauge solid I could use but I dont want to if there are any disadvantages other than solid being harder to work with....
please advise ... thanks in advance stain ps ...I will post pictures and update my blog soon but I have lost my camera and racing the cold weather!!!! winter is coming soon here
stain is offline   Reply With Quote
Old 10-08-2009, 11:50 AM   #2
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
It is better to use stranded for all applications that could be subject to vibration, including the 110 VAC, even though solid is the most commonly used.
Old 10-08-2009, 12:05 PM   #3
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Stranded. The finer the better.
In Aviation it is mandatory for a good reason. Vibration resistance.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 10-08-2009, 01:43 PM   #4
stain's Avatar
calgary , Alberta
thanks for all the help!!! back to work!!!! or play ????....
Old 10-08-2009, 05:37 PM   #5
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Believe it or not electricity travels on the outside of the wire not down the center.
Stranded has a lot more surface area and can carry more current over a same size solid wire. And like others more vibration resistant.
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 07:26 PM
where does this wire go? bullydogsmom Lights - Interior & Exterior 9 04-11-2009 06:54 PM
What wire should be used DonMiller Batteries, Univolts, Converters & Inverters 17 03-12-2009 11:40 AM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 06:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
