Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 09-02-2007, 07:22 AM   #1
kooblekidz
Profile:  1978 25' Tradewind
Roseland , Florida
1 battery or 2?
Hi all,
I've got a '78 Tradewind and the batteries are gone. I'm only going to use it once this fall and hate to buy 2 new batteries if I can get by with one. Is there any reason I can't limp by with one? Also, if I do should I leave a dead battery hooked up to the other cables? I'm going to be plugged in at a campground, but I know it's always better to have a good battery in the mix.
Eric Hedin
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
kooblekidz is offline   Reply With Quote
Old 09-02-2007, 07:37 AM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
You can limp by this winter with one, and if it's only going to be there "to have a battery", you can probably get by with a really cheap one. If you out a second, bad battery in there, hook up the positive terminal to the bad battery, but not the negative terminal. This will keep the positive terminal from dangling, and grounding, and shorting out.
Then, next spring, you can get a pair of good group 24 or group 27 deep cycle batteries to put in the there.
Change is inevitable, except from a vending machine
AIR#2611
Battery in a '58 bevman Batteries, Univolts, Converters & Inverters 3 03-28-2007 09:31 PM
Which Battery Craftsman Batteries, Univolts, Converters & Inverters 4 07-30-2004 10:01 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Getting a new Battery ChrisAich 2003 International CCD 0 10-09-2003 02:25 PM
