Old 03-17-2010, 02:35 PM   #1
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
07 Safari Stuck in Storage Mode ?
Taking trailer out of storage and it wont power up. The electric jack work's.No 12V into power converter. Store/Use switch dosnt seem to "Click" when put in use and no red lite. Lite is on short time and "Clicks"going to store.Sounds like a Relay is under front bed @ front. Possible source of problem ?
Thank's in Advance.
knunut is offline   Reply With Quote
Old 03-17-2010, 09:39 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Thank's in Advance.
Probably a dead battery.
Try plugging in the 7 way to your tow vehicle, should be able to get the tongue jack up and have the switch go to "use" while that's plugged in. Battery may be toast but might take at least a little bit of a charge while you drive.
Old 03-18-2010, 05:57 AM   #3
knunut's Avatar
2007 20' Safari
Installed battery's that had been charged over winter. But maybe not enough amps, but jack works ? Will try connecting Truck.
Old 03-18-2010, 07:43 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The newer trailers have the relays for store/use mode. I've seen several of them with those relays bad, and have replaced them. That's solved the problem on those trailers, and the relay isn't that expensive.
Old 03-18-2010, 07:47 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I had my 25FB do that once. When I plugged it into the tow vehicle and pushed the rocker button again, the red light came on. It has never done it since.
Brian
SuEllyn & Brian McCabe
Old 03-18-2010, 12:18 PM   #6
2007 27' Safari FB SE
McKinney , Texas
So is the red light supposed to go off? Mine seems to stay on no matter which direction I toggle the switch.
Krazyjohnny is offline   Reply With Quote
Old 03-18-2010, 12:26 PM   #7
moosetags's Avatar
The little red light is supposed to go off when you push the button to go to thew STORE position.
Brian
Old 03-18-2010, 12:41 PM   #8
knunut's Avatar
2007 20' Safari
I put a Temp hvy gauge wire jumper across solenoid.The lights and red stow/use lite came on. Bad "Solenoid" thank's everyone !
The light should be out in stow mode.
Also installed New Digital Thermostat, IKEA handle on screen Door and planned a couple more of those under $100 mod's.
Old 03-18-2010, 12:50 PM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Installed new digital thermostat? We have been looking all over for a 12V unit to replace the old spring unit which I am getting tired of rebuilding all the time. Where did you find the 12V unit?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-18-2010, 01:59 PM   #10
knunut's Avatar
2007 20' Safari
I installed a Honeywell Non Programmable RTH 110B. I followed there instructions .Using Heat only.Fan on Auto. Hg jumper on. Havn't used it ,as i don't have the new solenoid in yet. Hope it work's out. Look under the previous post "Best modifications under $!00 " ? for more info.there are other sources of info on the forum.
Old 03-18-2010, 02:03 PM   #11
knunut's Avatar
2007 20' Safari
I think "dreamstreamr.com" had info on thermostat replacement.Great site with updates to do.
Old 03-18-2010, 02:36 PM   #12
McKinney , Texas
So I wonder what is wrong with the switch? I will look at it more closely tonight while I am installing the new PD9260 Converter/Charger.
Old 03-18-2010, 02:48 PM   #13
knunut's Avatar
2007 20' Safari
Are you changing the converter in your 07 ? Is the original Bad?
Old 03-19-2010, 08:52 AM   #14
McKinney , Texas
knunt,
The original one was squealing and was not charging the batteries (overcharging) correctly. I had one battery that was almost totally dry and one that still had some juice in it. I am charging them now that I have the new Converter / Charger installed that has a smart (Charge Wizard) feature to see if they will hold a charge to determine if I need to replace them. I added distilled water to the one battery and connected them to see what I have got.
BTW the store/use switch light on my trailer only goes out if the shore power is not connected. I hope that is normal. While the shore power is connected it will not go out but the load seems to be taken off of the converter/charger due to the fan speed dropping when toggled into the store mode.
2008 Safari SE 27FB Front Storage Compartment wayner61 2008 Safari SE 10 01-29-2015 09:17 PM
Looking for Storage Tips on 20' Safari Dreamnair 2008 Safari SE 3 01-01-2009 04:11 PM
25 Safari SE FB - shower storage P&J 2008 Safari SE 17 01-13-2008 05:02 AM
