Old 07-13-2016, 08:25 AM   #1
2016 28' Flying Cloud
The Plains , Ohio
Thumbs up Zamp 160P
My new Zamp 160 portable arrived yesterday and just some initial comments.
First, I wanted to see if I could just remove the battery clamps and use the SAE connector with the existing batteryminder eyelets that I have connected to the batteries. The SAE standard is for the bare part of the connector on the battery side to be the negative terminal. I batteryminder is set up that way as I understand the Renogy solar is as well. The Zamp connector is wired opposite to that, with the bare battery side of the connector connected to the positive side. Not sure why they don't conform to the SAE standard.
I set up the charger and connected using the battery clips to two group 24 batteries in parallel that had been on maintenance charge with the low amp batteryminder. The Zamp activated and briefly went into a charge mode but quickly went into float mode, suggesting the batteryminder was in fact keep the batteries fully charged. I did notice when in float mode, the Zamp charger showed 0.00 when I clicked over to the charged capacity (amp-hour) setting. I wonder if this only shows a value while bulk charging. I am reluctant to discharge the batteries while the unit is just sitting in my driveway to test this. I guess I'll find out when we go the Shenandoah Big Meadows in August without hookups.
So for now my plan is to try to keep the batteries charged off grid with the Zamp, use my Honda eu2000's on cloudy days, and bulk charge at home with the stock Parallax monitoring the current with my clamp on ammeter. When the charging current goes to a few hundred milliamps, I'll switch over to the batteryminder which seems to be doing a good job topping off the batteries and keeping them charged in maintenance mode.
I suppose one of these days I may bite the bullet and change out the Parallax for a 3 stage converter, but maybe my plan will work. We'll see.
Richard
whitegs is offline   Reply With Quote
Old 07-13-2016, 08:44 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I made a gender changer using two SAE connectors to reverse the polarity of the Zamp (I use the 200) and that lets me use the same (permanently wired) SAE connector to the batteries ( direct means it bypasses the idolaters) for both the battery tender or Zamp.
martin300662 is offline   Reply With Quote
Old 07-13-2016, 10:12 AM   #3
The Plains , Ohio
Good suggestion
I've ordered a short cable with the two SAE connectors. Thanks.
Old 07-13-2016, 11:42 AM   #4
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
Zamp
Thanks for the post. I'm new to AS and I'm trying to understand why there is a
Solar Plug Warning "Only use Zamp Solar Portable Charging Systems". Is it because they don't comply to SAE standards?
80Ram is offline   Reply With Quote
Zamp Inverter??? arstrmlvr Batteries, Univolts, Converters & Inverters 9 01-25-2014 08:46 PM
Zamp 30 amp controller TG2500 Generators & Solar Power 5 06-11-2013 09:51 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
