Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 11-15-2015, 11:15 AM   #1
dznf0g's Avatar
Oswego , Illinois
Yet another Solar.....advice sought
A bit of background first: I have a portable Zamp 160 watt panel setup, which I will keep, as I camp in deep deciduous cover a lot; I had a 15 watt battery maintainer panel I used for storage only. Now, I keep the AS at home on a new pad and won't remove my batteries anymore.
Since the AS is at home, I wanted to be able to have lighting and furnace available for winter projects inside, and 15 watts wouldn't cut it in the dark, low sun angle days we have here. My calculations said 50 watts would be ample, but the cost was so close to a 100 watt Renogy, that I decided to go that route.
I fabbed tilt legs for 3 different required annual angles for my latitude and fashioned a bungee hold down system, with the wire running down the exterior to by battery compartment, where the pigtail is for my Zamp portable. There is a Morningstar Sunchaser 15 amp MPPT in the electrical center under the couch in the corner closest to you in the picture.
Now I think I might as well mount the 100 watt panel permanently and utilize it when I can for my camping style. I would get feet, etc. from AM solar.
Now, finally for my question: Considering that the temporary location for the panel is best for my storage situation, due to shading, compass angle, etc. how would you all recommend getting the wire run down to the controller, where I can parallel it in with my existing portable pigtail in the electrical center?
Here are the obstacles: cross members in the side wall; no way to get around the front pano if I were to come in at the Fantastic fan; same if I came in at the radio antenna.
The alternative would be to move the panel to the rear, behind (and utilizing) the fridge vent, but that would mean a lot longer wire run....it would however, reduce my already somewhat heavy tongue weight. That location would reduce my effective sun charging time by about an hour a day, due to tree shading (maybe not a big deal with 100 watts).
Any suggestions I am overlooking?
-Rich-
Old 11-15-2015, 11:40 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Go to the back and down the fridge vent. That will get you into a "work area" inside and to the floor. Easy from there. Also, there may be real estate for additional panel(s). You may not want to add now, but tomorrow is another day.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 11-15-2015, 12:23 PM   #3
dznf0g's Avatar
Oswego , Illinois
I think you're probably right, unless someone comes up with a brilliant idea. After bringing down the fridge vent it's an easy run to under the dinette seat, where a pvc conduit spans the dinette and comes up under the credenza. A second pvc conduit runs from under the credenza and spans the living room and comes up under the couch .
I suppose I should install a combiner box for possible future expansion, and oversize the wiring as well.
-Rich-
Old 11-15-2015, 12:42 PM   #4
2007 22' International CCD
Absolutely install a combiner box, and size the wire from the component to the charge controller as big as you can get to fit the lugs on the ends. For solar, bigger is better. Eyeball the roof area, imagine it filled with panels, and size for that.
There is no overkill, just "open fire" and "time to reload" --Howard Taylor, Schlock Mercenary
Old 11-15-2015, 12:57 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I was going to do the fridge vent, but that's a long way. I used the combiner box sold by AMSolar, and ran my wire down along the pipe for the black tank in the bathroom and to the controller which is near the batteries. Very short run.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-15-2015, 01:03 PM   #6
dznf0g's Avatar
Oswego , Illinois
Yeah, Bold, it's all about floorplan and access. Unfortunately, my vent pipe is across the width of the trailer and as far back as the fridge vent. Would add at least 15' of wire.
-Rich-
Old 11-15-2015, 01:04 PM   #7
1974 Argosy 20
Kooskia , Idaho
I don't know when Airstream started to put solar pre wire into their trailers, but there already may be some solar pre wiring which is heavy enough to handle the 100 watt panel you have now.
You might check your manual or Airstream factory to see if it is there, and where it is available on each end (if it was installed originally)
Old 11-15-2015, 01:05 PM   #8
Nomadic , USA
Yea, finding a good drop for a cable run can be tough.
Old 11-15-2015, 01:07 PM   #9
dznf0g's Avatar
Oswego , Illinois
Here's my floor plan
There is a single stack just forward of the front shower wall.
OOPs, that's for a 2016...I'll have to hunt for a 2007. Basically the same except I have a sofa across the front and a credenza forward of the front dinette seat.
-Rich-
Old 11-15-2015, 01:17 PM   #10
dznf0g's Avatar
Oswego , Illinois
Here it is:
Name:	Floorplan Airstream_Classic_30.gif
-Rich-
Old 11-15-2015, 04:39 PM   #11
dznf0g's Avatar
Oswego , Illinois
Yeah, I know exactly where both ends are, but they are not big enough for my use....and per solar wire charts. IIRC, it is a 12 gauge and wire chart requires at least 8 gauge for that run. (Going from memory here, will have to recheck ) but if I'm going to the trouble, I may go 6 gauge in case I want to expand in the future.
-Rich-
Old 11-16-2015, 10:52 PM   #12
2015 30' Classic
Pleasanton , California
Since you have two panels, put them in series and connect them to your Sunchaser MPPT controller and you shouldn't have any problem using the existing wiring. Your losses due to the wiring will most likely be less than 2%. Seems crazy to make more work for yourself if you don't need to
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 11-17-2015, 06:00 AM   #13
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Not sure if this will help, Go power solar makes a cable entry plate that allows you to go through the shell.
Bullit is offline   Reply With Quote
Old 11-17-2015, 06:37 AM   #14
Tincampers's Avatar
Sneedville , Tennessee
Thanks, just ordered one.
Tincampers is offline   Reply With Quote
Old 11-17-2015, 06:57 AM   #15
dznf0g's Avatar
Oswego , Illinois
I pondered that for awhile...but if I want to do this only once....and if I expand in the future, there may be a requirement to go series/parallel anyway. I'd rather only do the work once for the portion from the combiner box to the controller.
I have ordered the combiner box for the fridge vent, and rocker foot mounts from AM; and 6/2 marine cable and a bunch of other bits. I'll run down the fridge and through the under floor wire chases to the front. I'll install common power and ground studs in the electrical center for paralleling in the Zamp portable.
-Rich-
ADVICE SOUGHT updating 1996 Caravel plumbing kentercanyon Plumbing - Systems & Fixtures 5 02-16-2009 04:00 PM
'08-'09 Duramax Mud Flap Advice Sought AirsDream Tow Vehicles 10 01-21-2009 07:17 AM
DASH DIVING on 84 Excella 270 - Advice Sought N2XBW Classic Motorhomes 6 12-13-2007 05:34 PM
Simple Generator Needs Advice Sought scooterpie Generators & Solar Power 25 08-12-2007 02:18 AM
Newbie - advice sought. dbmarshall Our Community 10 10-11-2002 02:38 PM
