Old 07-19-2015, 09:11 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yamaha or Honda Generator?
Ok, I am going to buy a good quiet generator, 3,000 Watt, Honda or Yamaha.
It seems as if the Honda is quite a bit lighter, and the Yamaha is about $200 (10%) cheaper.
The Yamaha comes with the 12V charging cord, and I have to buy the cord for the Honda.
I want OPINIONS. Which one would you buy and why?
Old 07-19-2015, 09:14 PM   #2
Spokane , Washington
oh boy here we go again
Shaggy1970 is offline   Reply With Quote
Old 07-19-2015, 09:21 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you should buy a Yamaha 2400 like mine; OK, if it's the 3000, I would lean on the Yamaha, but if you buy a Honda, don't buy the Handi. In my opinion, the Handi is a more expensive model of the 3000 Honda that has been stripped to save weight.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-19-2015, 09:23 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yamaha or Honda?
Will your 2400 run your air conditioner?
This is of major importance to me!
I was thinking about the 2400 but I was shy about the A/C, if it will start and pull the A/C, I will put it back on my list.
Old 07-19-2015, 09:38 PM   #5
Salem , Oregon
Images: 18
Hi, I picked the Yamaha 2400 because it was the lightest single generator that would run my air conditioner. I have the 11,000 BTU air conditioner, but at high altitude, it ran my air, refrigerator, television, and converter. People with larger air conditioners have stated that they switched their refrigerator to propane.
All of my motorcycles were Hondas, so this wasn't a brand loyalty thing.
2005 Safari 25-B
Old 07-19-2015, 09:59 PM   #6
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I'm with Bob. After months of research I decided on the 2400 as well and for the same reasons as mentioned. The biggest reason was that it would and does start and run my 11,000 btu air. Besides that it's very quiet has a gas gauge and shut off that don't require you to run your gen dry to avoid carb issues. I love my 2400!
Mark,
The path not taken is the one I'm on...
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 07-19-2015, 10:53 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
As noted, there are 2 Honda 3000 generators. The Handi is the light one, the quieter EU3000is is comparable to the Yamaha EF3000iSEB and is nearly as heavy. The Handi has half the fuel capacity of the EU3000is and less than half the run time (according to Honda specs... they don't use the same engine.)
— David
Old 07-20-2015, 12:12 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
That is encouraging.
I have my original Armstrong AC, that I am pretty sure is 11,000 BTU.
I was concerned because I have a Champion generator that is ADVERTISED as 3,000 watt (3,500 surge) that barely starts my unit.
I liked the idea of the 2,400, but it freaked me out a little.
Thank you everyone for the helpful comments!
Old 07-20-2015, 12:19 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I was wondering about the weight disparity of the two brands.
I knew Honda offered two different models from my prior research, but had forgotten before my initial post today.
I used my Champion in a Lowe's parking lot last night, it isn't obnoxious lout, but it is just a little to noisy, especially when the ac cycles off.
It was cheap, and it got used several times, but it is time for an upgrade!
Old 07-20-2015, 12:35 AM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yamaha or Honda?
What is your real life run time with the 2400 with the ac running?
I spend a lot of time in the desert southwest, Texas, New Mexico, and Arizona.
Last night my a/c ran for four or five hours before cycling off the first time after a day of traveling in VERY hot conditions, it was heat soaked big time.
Are there external fuel tanks available for the unit? Seven hours of real life run time or better would work for me.
Old 07-20-2015, 01:19 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well, FWIW,,,, it is a done deal, I just bought an EF2400....
Old 07-20-2015, 11:08 AM   #12
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Good choice.... Let us know.
Mark,
Old 07-20-2015, 01:00 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Will do!
It should be arriving in two days, at which point I will be forced to tell my wife that I bought it....
Old 07-20-2015, 01:15 PM   #14
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Will do!
Or......Not!
Mark,
Honda or Yamaha Generator AraExpress Electrical - Systems, Generators, Batteries & Solar 9 12-28-2014 01:05 PM
yamaha vs honda generator SilverPalace Electrical - Systems, Generators, Batteries & Solar 40 09-22-2012 09:59 PM
Yamaha vs. Honda generator dbirkhead Electrical - Systems, Generators, Batteries & Solar 21 05-31-2012 09:18 AM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
