Old 05-23-2006, 11:53 AM   #43
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Originally Posted by richg
Where is the best place to purchase a Honda 2000??
Richg
I ordered both my EU 2000's and the parallel kit from these guys. Great customer service.
http://www.mayberrys.com/
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 05-23-2006, 01:34 PM   #44
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
RE my Yamaha order -
Good news - US Carb sent an email today saying that they have my order and my unit is to go to the conversion center next week! Fingers crossed, I may have it in a couple of weeks.
I'll keep you posted.
Pat
pmclemore is offline   Reply With Quote
Old 05-23-2006, 03:47 PM   #45
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Hello Pat,
Are you having your unit converted at the factory? Is this a kit I can order and accomplish myself? I'm diesel as well and would like to do away with carrying a five gallon gas can around and the subsequent weight if I can convert my 3000 myself. Thanks.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 05-23-2006, 07:42 PM   #46
Ready-to-Travel
pmclemore's Avatar
Zoom, I am buying the unit new from them, and having the conversion done by them at the same time. As for doing the conversion, Pick says he has done it, and at another time he has also sent them the carb for them to do the conversion.
He says that if you are handy, it can be done. I don't have the requisite confidence.
Pat
Old 05-23-2006, 08:14 PM   #47
ZoominC6's Avatar
Colleyville , Texas
Thanks Pat.
Old 06-02-2006, 10:00 AM   #48
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Tried getting thru to USCarb for 2 days. Finally got thru on the last day eligible for the Yamaha rebate. They are all out of 2400kw generators. They are sending me the conversion kit for tri fuel which does not drill the carberator. Found a local retailer who matched an internet price so was able to get the rebate, save on shipping and a few extra $$. I'll let you know how it goes.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-03-2006, 07:07 AM   #49
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by ZoominC6
Hello Pat,
Hey Zoom,
I recently converted a 7KW Onan Marquis from gasoline to LP using a kit from US Carb. The conversion is relatively straight forward and you can do it if you can remove and replace your carb yourself. It involves removing the float bowl and a few inlet fittings, drilling a new inlet, sealing up the old holes and re-installing it. Everything is in their kit including the sealant. It also includes a new 'pancake' demand regulator that must be attached to the gen somewhere. this is in addition to the 2 stage regulator that you should have on the LP tank.
It even worked when I fired it up the first time. GO FOR IT!!!! Go to their website and look for the conversion kits and select the one that fits your requirements.
Old 06-03-2006, 07:12 AM   #50
ZoominC6's Avatar
Colleyville , Texas
Thanks Lew. This sounds fairly straightforward. I'll check it out and let you know.
Old 06-06-2006, 12:24 PM   #51
Ready-to-Travel
pmclemore's Avatar
Good news for me! US Carb just sent me a notice that they are shipping my unit today!
By the way, their specs say that it will run a 13,500 RV ac and still have some amps to spare.
Pat
Old 06-13-2006, 03:06 PM   #52
Ready-to-Travel
pmclemore's Avatar
Yamaha Heaven at Last
Good news, all
I received the generator - Yamaha EF2400is tri-fuel exactly as ordered. I also ordered a hose and the quick connect ends. Everthing arrived together in a well-packaged box.
US Carb sent excellent instructions on how to service and get started. They are very clear. The generator started on the first pull (gasoline) and I have run it for about two hours so far - under partial load and under no load. Today, I hooked it up to propane, and it worked like a charm.
I can't say I'm happy with their communication process, but the generator and carb mod seems to be perfect. I trust my earlier worries will fade away like they always do.
Pat
Old 06-13-2006, 03:15 PM   #53
peegreen's Avatar
Pat,
Have you tried the generator with the A/C and any other loads in the trailer? I just picked up the 2400 and ran it with the A/c. The first compressor start went ok - a little straining on both ends. The next start tripped the breaker for the univolt. I'm nervous about real time in the heat and when the dog is left inside.
WBCCI 24291
New England Unit
Old 06-13-2006, 03:51 PM   #54
TIMEMACHINE's Avatar
Huntington Beach , California
To All,
After running the Yamaha 2400, how would you characterize the noise level compared to other inverter type gens? I understand that it does not have the econo throttle feature available on the Yamaha and Honda 3000s. How does the noise level compare to twin Honda 2000s?
And if anybody has been using the 2400 for a period of time, how is the fuel consumption?
Thanks for any details that would help.
TIMEMACHINE is offline   Reply With Quote
Old 06-14-2006, 07:22 AM   #55
Ready-to-Travel
pmclemore's Avatar
Peegreen - I haven't tried my ac yet, but your report doesn't sound too good. My ac is 11,000btu. How about yours? We're having a very nice rainy day here, thanks to the ex-tropical storm, or I'd take the gen out to the trailer and fire her up. When I do it, I'll report back.
Timemachine - when not under load the gen runs at a pretty smooth 2600rpm (US Carb included a tach/hourmeter). When I apply a load, it increases a bit.
As far as noise, it is as quiet or noisy as a Honda I camped next to in the Smokies last year. Of course, since I didn't have one myself, I remember thinking that one was noisy as heck.
Pat
Old 06-23-2006, 10:24 AM   #56
Ready-to-Travel
pmclemore's Avatar
I fired up the Yamaha and let it settle in to warm up, then turned on my AC. The unit went from idling at 2600 to about 2970 very smoothly, and stayed there. Little or no increase in noise.
I think it will be just fine. It starts very easily on gas or propane. It is a bit heavy (70lbs or so) but Page and I can lift it into the truck bed without straining.
I think I have a keeper!
Pat
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Yamaha Generators Bilouie Generators & Solar Power 27 04-23-2006 04:14 PM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
Solar and Generators Melvin P. Thorpe Generators & Solar Power 43 05-11-2003 08:51 AM
Generators...one more time! APB Electrical - Systems, Generators, Batteries & Solar 0 03-09-2003 08:52 PM
