Old 02-21-2007, 11:03 AM   #29
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The EF2400is starts and runs equally well with Gas or Propane. In fact, you can be running on propane, flip the fuel switch to run on gas while you go find your spare propane tank, hook up, then switch back. Or vice-versa.
As for propane, since I have a diesel truck, it is especially nice not to have to mess with gasoline at all.
Pat
pmclemore is offline   Reply With Quote
Old 02-21-2007, 01:43 PM   #30
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
From what I remember the "Boost" is only available on models with electric start. The way I understand it is the generator is able to use the starter batery as a capacitor to get this brief boost. Check the spec but I think that with Yamaha the 2400 in the model number is the short term max output.
The trifuel vs dedicated conversion question is one reason I've procrastinated making the switch. The trifuel seems a little easy for an owner conversion and it can be "undone". The dedicated conversion requires drilling the carb and replacing the jet. I really don't foresee EVER running on gasoline once I make the switch. However the comment about switching from propane to gasoline while changing tanks is interesting. Has anyone run a generator with a pair of tanks that have an automatic change over regulator? Will that let the generator continue to run?
-Bernie
bhayden is offline   Reply With Quote
Old 02-21-2007, 02:39 PM   #31
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by David Alan
I have never heard of a hard start kit but it sounds interesting, Do you know a source or have any information on the kits?
David,
Back in my fast-food days, I watched with fascination anytime the K-way system, a device used to make carbonated water for soft drinks, had a new compressor installed. Every so often, a new compressor would not reliably start up (it would just sit there & hum) and the technician would install a hard start kit (available from refrigeration supply houses). All the kit was was a bigger start capacitor.
Once running, though, the capacitor's job is done, and it makes no further contribution. There will be no reduction in running load.
Keep in mind that the only thing a start capacitor does is 'kick' the motor into spinning in the right direction. After the motor is spinning (i.e. not sitting there humming doing nothing) the hard start kit's job is done.
Tom
Old 02-21-2007, 05:17 PM   #32
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
David, I was having one installed on my guest house AC unit. Turned out it was already on the compressor. My AC guy was familiar with the request. I think it is a relatively simple start capacitor that is wired on the compressor wire feed.
Phil Gobie is offline   Reply With Quote
Old 02-21-2007, 07:28 PM   #33
lewster's Avatar
Naples, FL , Hood River, OR
Look at the leads on your A/C and find the start capacitor. It is the one with 2 leads...one in and one out. Check the rating of the cap and just get a bigger one (larger microfarad rating).
If you have ever heard those outrageous car stereo systems with the bass that will blow you out of your car from across 4 lanes of traffic, they also use very large capacitors (or bank of caps) as a boost feature to a provide clean audio signal to the subwoofers at times of peak output so the amps won't 'clip' the signal and distort the resultant sound.
A larger start cap on a roof A/C will do the same thing for a lower wattage start. The actual start-up will be a little delayed while it charges up, but the result should be positive with no motor damage.
You should also check the amp rating of your compressor and blower motor to see if the intended generator will power it .
Old 02-21-2007, 08:14 PM   #34
New Borockton , Alabama
Images: 21
Rodney,
FWIW, my 2500 watt propane Onan does run my 13.5 air conditioner and came stock as an option in my Lance truck camper that I use for hunting and fishing. I was surprised it ran it so well but admittedly, there is not much left over. I would not even attempt to run a coffee pot or toaster at the same time. Hope this helps.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 03-03-2007, 06:00 PM   #35
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Any reason not to?
I am trying to decide/figure out how to incorportate the new genset into my travel habits. One idea that I find attractive IF it is safe and doesnt have any disadvantages that I havent foreseen is to store it and run it from the bed of my pickup. The pickup bed has a shell over it so the gen would be out of the weather. I am assuming that the bed would be ventilated sufficently for this. So what would be the downside or danger to doing this? I have attached a pic of the truck if that is of any help.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-05-2007, 11:23 AM   #36
Ready-to-Travel
pmclemore's Avatar
Rodney,
I think you have plenty of exhaust ventilation, but I would watch out to be sure you had adequate heat-dissapating airflow. If your side windows will open and you can open the rear hatch, that should be good even in the summer. However, I would monitor it closely until you were satisfied.
Betcha can't wait!
Pat
Old 03-07-2007, 01:59 PM   #37
2007 25' International CCD
Martin , Georgia
I just ordered an EF2400iS tri-fuel. They quote 3 to 4 weeks on delivery. They were expecting a delivery from Yamaha any day.
We want to do some camping in some NPS mountain campgrounds that don't have hookups.
I'm planning to use it from the pickup bed and store it in the toolbox.
Dawgfan is online now   Reply With Quote
Old 01-12-2015, 09:39 AM   #38
White Lake , Michigan
Originally Posted by Boondocker View Post
Im about to pull the trigger on the Yamaha ef 2400is with propane conversion from US Carburator. Anyone have this unit? Does anyone know what the change is from the EU to the EI serries? And who has done business with this company? Here is the link: EF2400is
thanks
I would steer clear of them! Here is my complaint letter to them
Six Year Saga Finally Resolved
My father, brother and I purchased a tri-fuel Yamaha generator from you in October of 2008 for our partial year cabin use. Upon initial receipt we had a very difficult time getting the device started on propane fuel. During the week of install we spent no less than 25 hours installing and messing with the load lock to get the device to start effectively and run at peak. In the end we settled for running at peak and lived with the hard starting due to lack of fuel and waiting for it to go through the regulator. We also bought a service policy as my father was concerned about the tri fuel set up and how it would work.
My father has been doing most of the communication with you regarding the fact that this thing wasn’t working right from the beginning of ownership. During the 1st year of the service policy he asked to get a spare starter as he felt this could be a point of failure (This was refused). He had numerous calls to your tech support and engineering to try to drive to a fix. To no avail! During my father’s visits to the cabin I would spend several hours a week with him trying to trouble shoot it from a phone call. A year and a half in you guys sent him a replacement regulator with a needle seat priming mechanism on the front and stated that this was designed and developed to fix the hard starting conditions (Experienced 10-15 seconds of cranking the starter in order to get it going). Your paperwork stated that this new regulator set up was put on a machine in your shop and tested and performed perfectly (There is no way for this had been tested on a cold start as you will see by our findings). My father replaced the original regulator with the new regulator and nothing changed. On a cold start it still exhibited 10-15 second of starter cranking to get propane in to the carb. So for the entire six years of ownership we have spent countless hours to try to get this thing running right. Completely ridiculous to get vacation or time off and get to go to the cabin only to experience the headache of having to constantly mess with this generator to get it started. During this time we have ruined two batteries as a result of the excessive cranking in order to start.
This past October 2014 my father was at the cabin with my two sons and experienced the straw that broke the camel’s back. The starter broke! So now after spending $250 dollars in batteries we are forced to buy a starter for $498. So this starter went out in its sixth year with less than 360 hours on the machine. This too is ridiculous and is a direct result of your faulty design! When we ordered the starter from the Yamaha store the tech advised that he has NEVER replaced a starter on this model of generator EF6600.
My father, brother and I had one more trip planned in November. We had no choice but to order the starter and incur this expense. We installed the starter and it performed as designed, but still required excessive cranking.
I arrived at the cabin right after the new starter was installed and now while on site I am trying to understand why your redesigned regulator/primer is not working. I have spent 30 years in manufacturing and as I was investigating your fix it was obvious to me that the front mounted needle and seat could not be providing early fuel for the cold start. Now mind you that my father had called several times talking to your techs and engineers and they ensured him if the needle and seat was turned out 2.5 turns it would work fine (Even though the documentation states 1 turn). Upon my inspection it was apparent there was no early fuel flow happening and tech comments were not true, there was NO change on cold/hot starting with any change on the needle seat adjustment. If you look at the attached picture you will find that the inlet nipple is drilled and tapped into a location on the brass T that when the load lock is set correctly the nipple is blocked by the load/lock bolt inside the T.
Root Cause:
I would say the root cause of this happened when the T was drilled/tapped for the nipple it was loaded into the drill press fixture backwards so it was drilled on the load lock/bolt side. I believe you would want the nipple inlet away from the load/lock bolt side for free flow gas (RED Arrow) from the primer system. If oriented 180 degrees opposite in the fixture the nipple would be where the red arrow is. See picture below
After disassembly it was evident that the flow into the nipple/T (BLUE Arrow) through the small hose above was blocked by the load/lock bolt and no gas could enter no matter how many turns on the needle seat. I tried to reverse the T but the threads were different from the 3/8” pipe thread on the left vs. the machine threaded bolt.
The Fix:
In order to permanently fix the unit we will need a T where the nipple is drilled/tapped closer to the pipe thread side so there is no chance of the Load/Lock bolt to block the opening when set properly (RED Arrow).
Field Fix:
In order to test our theory we utilized the original T (with no nipple tapped into the top) and had to purchase some extra fittings (YELLOW Arrow) and flow gas through two T’s in order to get unobstructed flow through the primer solenoid and small gas tube.
After completion of our field fix we set the needle seat to 1 turn (As documentation stated) and upon cold start if fired up in 1-2 seconds of cranking the starter. Subsequently we have fine-tuned the load/lock and the generator runs perfectly under load and the primer needle seat is about ˝ turn and generator fires up within 2 seconds.
It amazes me how one wrong machined T on your part completely eliminated your fix from working. I can’t tell you how much frustration, wasted time and effort we experienced over 6 years of ownership, while constantly working on the generator after spending an initial $2812 on Invoice #9649 dated 10/7/2008 with you for product that DID NOT perform. Plus $498 for a replacement starter (that has no history of ever being replaced in the field) and $250 in 2 batteries worn out.
I have to say I am expecting you to send me a new load/lock T where the nipple is drilled/tapped on the proper side and some form of financial help for the extra $750 dollars we had to spend due to the faulty initial design and interim fix that DID NOT work.
In the end after fixing the product with the field fix last week I am happy that our field design worked and now the product works as it should have 6 years ago.
Please advise, on how you will remedy our issues.
Sorry pics wouldn't copy over
After 2 months of following this up they refuse to remedy our losses and issue
nabozny is offline   Reply With Quote
Old 01-12-2015, 10:09 AM   #39
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Bummer. I've had my 2400i trip-fuel since 2007 and never had a problem.
2012 Dodge Durango Hemi/AWD
Old 01-12-2015, 10:28 AM   #40
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Bumping a very old thread...?
And I've had our Honda dual fuel since 2007, still putt'n great!!
Old 01-12-2015, 11:12 AM   #41
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Only complaint with USCarb was they initially sent me the wrong kit for my EF2400iS.
They corrected the problem by having me ship them my carb, where they modified it and shipped it back. Put it back together, along with a chrono, and it works great.
boondockdad is offline   Reply With Quote
Old 01-12-2015, 12:43 PM   #42
I was wondering how you made out with Yamaha.
Had to do the same thing with the Honda carb, but I knew that in advance.
The new kits have a billet aluminum manifold that fits under the base so no mod's are needed.
Their CS was pretty spotty back then, some say it's improved quite a bit, but I've had no contact with them to know for sure.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
