Old 08-20-2017, 08:51 PM   #1
kootenayken's Avatar
1976 Argosy 22
cranbrook , British Columbia
Yamaha EF 2000
We have a FranklinChef 1.0 Cu Ft Microwave - It says 1400 watt input power and 1000 watts cooking power. We purchased a Yamaha 2000 it's rated at 1600 watts countinuous use. When we use the microwave it maxes out the RPM and lights up the overload light in 30 seconds. Is there something I am missing or did I get the wrong generator?
kootenayken is offline   Reply With Quote
Old 08-20-2017, 09:26 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What else do you have running? ie converter, refer on electric, etc.
Doesn't take much to eat up the 200 watts difference in the load verses the generator capacity. I would bet you are exceeding the 2,000 watt capacity with these other loads.
Old 08-21-2017, 09:22 AM   #3
1976 Argosy 22
Good point, no lights or fans on. But it is going through the Inteli Power 45 with battery battery charger. I can turn the battery charging off, will the inverter by itself use up much power?
Old 08-21-2017, 10:37 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe you are referring to a converter not an inverter. Turning the unit off will remove that load.
Is your refer on electric or gas?
Do you have other 120 volt devices in use? Hair dryer, toaster, coffee maker etc.
I regularly run my Yamaha 2KW unit with a 1,500 watt space heater as a load. Have not experienced the overload situation.
Old 08-21-2017, 11:22 AM   #5
1976 Argosy 22
Refer is on gas and nothing else that I can think of. Just the microwave.
Old 08-21-2017, 03:29 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did you try it with the converter off?
Old 08-21-2017, 03:41 PM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
One other item to consider is your altitude. You need to de-rate the generator capacity by 3% for every 1,000 feet you are above sea level. At 5,000 feet, for example, your 1600 watt generator becomes a 1400 watt generator.
Also, try running the generator with the "eco mode" off (or whatever it's called.) That should force the generator to run at higher RPMs before it is loaded and reduce the impact of the microwave's start up draw.
One last thing, make sure the oil level in the generator is topped off.
I've personally learned all the above over the years by direct experience. ;-)
Bob Martel
WBCCI# 5766
Old 08-22-2017, 09:37 AM   #8
1976 Argosy 22
Thank for the tips. Seems to be the battery charger on the converter that comes on as soon as I start the generator along with the microwave start up that sends the generator into overload. Another problem solved by the forum.
Yamaha 2800 vs the Yamaha 2400iSHC gaylejoe Generators & Solar Power 14 04-30-2017 08:55 PM
Can a Yamaha 2000 run my AC? gomotomoto Boondocking 19 07-17-2015 05:59 PM
Question on Yamaha EF2400iSHC - 2000 Watt Inverter Generator. Ditter Generators & Solar Power 22 02-19-2013 06:31 PM
Generators -- Honda 2000 vs. Yamaha 2400 Redcobra Generators & Solar Power 33 03-07-2011 11:12 AM
Yamaha EF 2000 IA vs Honda EU2000 IA Chasmorgan Generators & Solar Power 14 07-15-2010 04:56 PM
