Old 05-13-2007, 12:51 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Yamaha 2400is trouble shooting
My 2400 stoped while running on gas. It looked empty so I didnt think much about it. I refilled it and now it doesnt start. What is the trouble shooting routine on this? I half suspect a clogged filter but thought I would toss this out there before doing damage on my own. Thanks
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-13-2007, 12:57 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Rodney,
It won't run without: fuel, spark and air. I would be sure it's getting spark at the plug, fuel to the carb and a clean air filter........new fuel filter isn't a bad idea either.
Try it and see what happens before you dig deeper.
Old 05-13-2007, 02:26 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I spent about 4 years working on small engines. A common problem once you've ruled out the obvious, is water in the fuel. There are many reasons why you may get water in your spare gas tank, which then gets transferred to your gen-set or lawn mower or chainsaw, etc. You may not think you could have water, but check it.
Take the fuel cap off, and look into the fuel tank with a flashlight. You need to see all the way to the bottom of the tank. Water will sit at the lowest point, and will look like a bubble in the bottom of the tank. Of course, if it's a large amount of water, you will see a seperation line part way up the side of the tank.
If you have water, you can use a non-electrical (!!) vacuum unit to suck the water out. You then need to get the water out of the carburator, either by a carb bowl drain, or by disassembling it.
Good luck, hope it's easy.
Dave
Fyrzowt is offline   Reply With Quote
Old 05-13-2007, 02:39 PM   #4
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Also, a spark plug needs to be clean and with the proper gap, which is .025". For reference if you don't have a feeler guage, a credit card is .030 and a typical business card is .020".
If in doubt, spark plugs are cheap - get a new one.
Dave
Old 05-13-2007, 03:10 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
OH FOR PETES SAKE! The spark arressor is COMPLETELY plugged with carbon . Dead dinasaurs should not do this in 30 hours of running. Should I expect this to have damaged the unit? I will be taking some deep breaths now....
ID:	37256   Click image for larger version
Name:	clogged spark arrestor.jpg
Rodney
and the
My Blog
Old 05-13-2007, 05:03 PM   #6
lewster's Avatar
Easy Fix!
Glad you found it without too much other 'investigating'................
Old 05-13-2007, 05:07 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by lewster
Easy Fix!.
I dont know, I havent got it started again. Is there any way this may have damaged the motor? And what is the deal with all that carbon, shouldnt the carb have been set before I got it?
Rodney
and the
My Blog
Old 05-13-2007, 05:10 PM   #8
lewster's Avatar
I'm no small engine expert by any means, but it looks like it's running RICH from all that carbon. You might check the manual to see if there is an adjustment for the air/fuel mix.
Also, even if the mix is set properly and the air filter is clogged or the air passage is blocked, that would also contribute to the rich running condition. Better check the air intake and filter while you're at it and make sure that the proper amount of air is entering the unit.
Old 05-13-2007, 05:35 PM   #9
Dwight's Avatar
1999 34' Excella
Joshua , Texas
carbon
Just clean the spark arrestor with a wire brush and be careful not to damage it. Your owner's manual most likely tells you how often to clean it. The Feds required them for engines that would be used in National and Federal areas so as to prevent sparks coming from the exhaust and starting fires. Engines require 3 things: fuel, air and spark - I would start looking at the source of each one and narrow it down.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-13-2007, 05:57 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rodney
you can burn the carbon off with a propane torch.
looks like you need to tighten up the jetting a bit. not using any oil are you?
john
you call them ferrets, i call them weasels.
Old 05-13-2007, 06:19 PM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by john hd
rodney
john
It doesnt look like it started using oil. Ready for a laugh? The manual says for owners to take the thing in for carb adjustment on account of how hard it is to do right. Maybe THEY should have sent it to someone. This is really frustrating what with it being a new unit.
Rodney
and the
My Blog
Old 05-13-2007, 06:50 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Have you pulled the plug? With that much carbon your plug might be fouled as well.
Richard
Old 05-13-2007, 07:02 PM   #13
lewster's Avatar
Rodney, try carb cleaner for your spark arrestor. I use it regularly on carboned up diesel burners that are part of the Aquas-Hot heat/hot water systems on the big rigs. Works like a charm and NO DAMAGE to the mesh.
Old 05-13-2007, 10:33 PM   #14
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Rodney, after you get the screen clean, and the spark plug clean (use a wire brush and maybe some carb spray on the plug), it should start again - I'd be surprised if it didn't. At that point, the carb probably needs to be leaned out a bit. This is much too soon to see that much carbon, it appears that it's just running too rich.
Dave
Folding step trouble, 1977 31' Sovereign JohnGalt48 Steps 13 09-10-2011 06:45 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
12V trouble.... Chuck Electrical - Systems, Generators, Batteries & Solar 8 07-06-2002 04:57 AM
Help Trouble posting image to FOR SALE FrankR Forum Admin, News and Member Account Info 9 05-01-2002 02:03 PM
