Old 01-18-2009, 04:43 AM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
YAMAHA 2400 / USCarb install
I can't get any tech support from these guys... I sent them an email yesterday (help@uscarb.com) and it bounced back... sent another via their webpage several days ago- nothing... WTF... phones go unanswered
I'm wondering if these guys sent me the wrong kit
ordered Type 'C' for 2400is (I got it about 3 months ago, and am just now getting around to the conversion)
the 2400 isn't even listed on their website, anymore
I've attached a pic of the uscarb load block, sitting on the bolt extenders at the carb... it appears there is a serious alignment problem
has anybody done this conversion?
thanks
Name:	uscarb load block install sm.JPG
boondockdad is offline   Reply With Quote
Old 01-18-2009, 08:25 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
People have had problems with them getting back to them. There are some threads on this if you try the search. But someone should jump in soon..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-18-2009, 08:44 AM   #3
Dearborn , Michigan
Images: 21
yeah, its odd... before they had my money, they were extremely helpful... crazy
Old 01-18-2009, 08:45 AM   #4
Dearborn , Michigan
Images: 21
I've posted some other pix...
Picasa Web Albums - JOSEPH - YAMAHA EF2400...
Old 01-20-2009, 05:03 AM   #5
Dearborn , Michigan
Images: 21
update: got a tech on the phone. it appears YAMAHA modified the carb since the time I ordered the Tri-Fuel conversion kit... so... I'm sending USCarb the carburetor to modify... he tells me it's a cleaner modification, as there is no 'adapter block'.. the fuel load will be directly on the carb... still tri-fuel ready...
fingers crossed
Old 01-27-2009, 04:57 PM   #6
Dearborn , Michigan
Images: 21
shipped the carb two-day air, got it back four business days later- looking like this:
nice. no 'load block'. clean.
I'll install tomorrow, and give her a test run
Old 01-27-2009, 05:04 PM   #7
Dearborn , Michigan
Images: 21
btw- forget email/webform for communication... the previous three phone calls were answered second ring, and the gal on the other end was extremely helpful
Old 01-28-2009, 12:00 PM   #8
Dearborn , Michigan
Images: 21
Installed carb, hoses, and regulator this afternoon
Hooked up to a 20# full tank
after priming, and a few pulls, it started right up
sounds like it might be running a little rough- compared to breaking it in on gasoline
idles at 2620
revved to 3130 with (2)1000w halogen shop lights
Old 01-28-2009, 01:53 PM   #9
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Clean install
Nice clean regulator install Joe, looks great.
On our Honda I did have to make several mixture adjustments before I got a nice smooth idle. Right at 3k in eco mode, changes nicely under varying loads. Have you made any adjustments yet? The carb mod looks exactly like what was done to mine. Keep those inside lines as straight as possible<< ask me how I know.
Are you using the quick disconnects on the supply lines?
Glad to hear the c/s has been improved. Maybe they have been visiting here!!
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-28-2009, 02:37 PM   #10
Dearborn , Michigan
Images: 21
hey bob,
yeah, i put a quick on the regulator
it says to use the primer button very sparingly, as flooding with LP is much easier to do... but so far i've found i gotta smoosh that thing 2-3 times, 1 second holds, before she catches and gets going...
i'm not totally convinced the carb mod is better than the load block... the load block had nice linear fuel ports circling the main venturi... where as the carb mod has a single pipe sticking through up top past the choke... i'm no grease monkey, but isn't fuel/air mixture quality real important?
Old 01-28-2009, 03:10 PM   #11
Don't worry too much about that primer button, I also found that more than one prime is needed on a cold LPG start-up. I use the long supply line so it takes a long time to purge.
One trick I used this past season...When shutting down, I turn on the gas, shut off LPG. When it's time to re-start it's ready to go on gas, reverse the process, when it starts to stumble turn on the LPG. Haven't had to use it often, only after running out of LPG.
I had the same concern about the delivery tube in the carb venturi. It took some trail & error, but after some mixture adjustments all is fine. Been averaging about 25+hrs on 11lb bottle.
Name:	PROPANE CONVERSION, HONDA 2000 014.jpg
ID:	74759   Click image for larger version
Name:	PROPANE CONVERSION, HONDA 2000 008.jpg
PFC
RLC
Old 01-28-2009, 03:56 PM   #12
Dearborn , Michigan
Images: 21
25+ hrs, yeah!
and i bet you just toss that LP tank in the burbs hatch... can't do that with a gas can! unless, of course, you enjoy breathing noxious fumes..
thanks for the pix.. gonna steal some of your install details...
Old 01-28-2009, 05:13 PM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Hey joe- Can you post a side view of that. It looks like it doesn't stick out as far as mine.
Old 01-28-2009, 05:42 PM   #14
Dearborn , Michigan
Images: 21
side...
Generators -- Honda 2000 vs. Yamaha 2400 Redcobra Generators & Solar Power 33 03-07-2011 11:12 AM
Yamaha 2400 owners? wantostream Generators & Solar Power 23 09-02-2009 09:33 AM
Yamaha 2400 & US carburetion - anybody done it sigv Generators & Solar Power 7 09-06-2008 05:16 PM
Yamaha EF4500ise Happycampers Generators & Solar Power 11 03-18-2008 09:09 PM
Yamaha Generators, again... Tavis76 Generators & Solar Power 63 10-17-2006 07:21 PM
