Old 01-30-2009, 03:42 PM   #29
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by finalcutjoe View Post
OK, fine tuned a few things...
I put a 90 degree elbow where the LP quick connect goes on mine. I think it puts less stress on the mounting. Of course mine is the old style so the whole regulator sticks out farther.
Old 01-30-2009, 03:56 PM   #30
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Originally Posted by halimer View Post
I have lifted and used a 2400 last summer at the Vintage Trailer Jam in Saratoga, NY, thanks to the Yamaha factory representative. It was not a problem. I have to lift my 45lbs dog into the backseat of my Ford F 350. At least the Yamaha has handles. I read the nightmare stories about USCarburator. I really don't care where the install is, I just want it to work.
Thanks.
Mark
if its got a neck and tail, its got handles...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 02-01-2009, 01:04 PM   #31
Dearborn , Michigan
Images: 21
did some amp draw testing...
30A Radio Scrap ammeter, and a modified extension cord...
1000W Halogen shop lights: 6.0A @ 2750 RPM
4GAL 'RIGID' shop vac: 11.0A @ 2780 RPM
2HP/4GAL Campbell Hausfeld air compressor: 30+A @ 4380 RPM.. wouldn't start it
plugged into Edison, it spikes the ammeter well past 30A, then drops to 14A draw while spooling
Is there any way to run this off my 2400?
btw- I started another thread titled 'hard-start kit?'
Old 02-01-2009, 01:09 PM   #32
Dearborn , Michigan
Images: 21
I need to get an 'L' bracket, and secure it... having that long hose extension creates a lot of stress on just those two mounting points...
Old 08-03-2009, 01:39 PM   #33
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I bumped this thread just to make a note and ask about exhaust:
When I run on propane, the exhaust smells pretty strongly of sulphur - how about your guys?
Also, my unit will not run my 15k ac. Other than that, I'm looking forward to dry-camping in Algonquin Park and other places beginning next week.
Pat
pmclemore is offline   Reply With Quote
Old 08-03-2009, 02:20 PM   #34
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
My small genset (Yam 2400 from US Carb) runs fine on all three fuels, and does not have as much "exhaust smell" on natural gas or propane as on gasoline. In any event, it still has some CO output that you can't smell, so as they say in real estate, location, location, location.
Mine runs my ac o.k. ... a few weeks ago, I ran it all afternoon in 97 degree heat / full sun on the coach, and it worked fine, but my ac is 11.5k or 13k, I don't know which. I will note that in that temp, the ac compressor ran more or less full time, but the interior kept at 72 degrees on "medium cool" setting and not "turned down" all the way on the temp dial. The heat from the genset air cooling output did kill all the grass where it sat on the ground ... YMMV.
AirsDream is offline   Reply With Quote
Old 08-03-2009, 03:02 PM   #35
Wayne&Sam's Avatar
Images: 21
I notice normal smell on gasoline, haven't noticed any on LP.
Old 08-03-2009, 03:59 PM   #36
Dearborn , Michigan
Images: 21
I'm checking the exhaust smell right now... running the genset on LP in my office at full load... I've closed all the windows so as to get a good sampling... doesn't smell too bad... actually, very soothing.. i'm feeling vera'dy'h kd;;kdkl d...dkak'doeiw]
09;ll;;;;;;,,,,mbbbbbbbbbbbbbbbbbbbbbbbbb
Old 08-03-2009, 05:55 PM   #37
Ready-to-Travel
pmclemore's Avatar
I'll have what he's having.
Old 03-23-2010, 04:27 PM   #38
ThermalCookr's Avatar
Utah County , Utah
Has anyone bought a multi fuel generator from Generator Sales? GeneratorSales.com
If you did how did the unit operate and were there any problems?
Mark
I've bought both the completed modified Honda EU2000i generators and the conversion kits from Central Main Diesel (GeneratorSales.com) and haven't had any problems with the generators or working with the people there.
My only experience is with converting the Honda EU2000i but it turned out to be a fairly simple procedure from what I initially thought it would be and because so, I've modified almost a dozen EU2000's myself for other individuals using CMD's kits and they've all worked great. I've not had any complaints from anyone who has gone through the conversion process or with the parts of the kit.
The hardest issue I've had to deal with is adjusting the valve that regulates the propane flow from the regulator into the carb to the altitude where I live. There's a small range where the turn of the valve can either let to much propane in or not enough causing the generator to start or not.
ThermalCookr is offline   Reply With Quote
Generators -- Honda 2000 vs. Yamaha 2400 Redcobra Generators & Solar Power 33 03-07-2011 11:12 AM
Yamaha 2400 owners? wantostream Generators & Solar Power 23 09-02-2009 09:33 AM
Yamaha 2400 & US carburetion - anybody done it sigv Generators & Solar Power 7 09-06-2008 05:16 PM
Yamaha EF4500ise Happycampers Generators & Solar Power 11 03-18-2008 09:09 PM
Yamaha Generators, again... Tavis76 Generators & Solar Power 63 10-17-2006 07:21 PM
