Old 04-30-2011, 09:22 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Yamaha 2400 motor surging
Started up the Y2400 after the winter. Was running fine before. Starts now runs but surges a bit every second or so. It produces elect. Whats wrong? I checked the air filter and took the wire brush to the spark plug. Ideas?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-30-2011, 09:32 AM   #2
tpi
Trabuco Canyon , California
Many times when small engines surge or run poorly after a layup it is due to fuel deposits in the tiny carburetor passages. The fuel evaporates leaving the deposits.
There's a product called Stabil to add to fuel which is supposed to help with this as preventative measure . I've found with my Yamaha generator running carb out of fuel on the last shutdown has prevented this.
If the surging continues, you'll probably need to disassemble carb and clean it.
tpi is offline   Reply With Quote
Old 04-30-2011, 09:36 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
It seems to be working its way out of the system. Never had this problem in the past, but the gen set is five years old and gets a lot of hard use. I guess I should expect things to start cropping up now and then.
Rodney
and the
My Blog
Old 04-30-2011, 09:53 AM   #4
1988 29' Excella
Livingston , Texas
Howdy!
Try running some "Sea Foam" through it. Sea Foam is a fuel additive that will help clean the fuel system and like Stabil also acts a a fuel stabilizer. I have used it with good results. You can find it at most auto parts or Walmart
"Happy Trails"
chiefneon
chiefneon is offline   Reply With Quote
Old 04-30-2011, 09:56 AM   #5
JFScheck's Avatar
Rockville , Maryland
Images: 33
And remember to run the generator with the fuel shutoff engaged so you can burn any fuel left in the carb.
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-30-2011, 10:45 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had this problem with my Honda EU1000i a few years ago. Running it with eco off with some carb cleaner in the fuel for an hour took care of the problem.
Richard
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Yamaha 3000 Bluto Generators & Solar Power 34 01-22-2012 06:43 AM
Generator Questions from a Rookie bertheep Generators & Solar Power 52 04-21-2011 01:24 PM
LP-fueled generator power fallacy boondockdad Generators & Solar Power 2 03-31-2011 04:35 PM
