Old 12-24-2007, 09:59 AM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Yamaha 2400 & US carburetion - anybody done it
I just purchased a Yamaha 2400 Generator - was thinking about buying the tri fuel kit from us carburetion.
Anbody installed one of those? How hard was it? I am a semi-mechanically inclined computer guy and wondering how viable it would be for me to install this.
How well does it work?
Any thoughts / suggestions much appreciated!
sigv is offline   Reply With Quote
Old 12-24-2007, 10:08 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Use "Search" and you will find a lot on this. I bought mine with the conversion already installed. Works great.
Old 12-24-2007, 12:19 PM   #3
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
So if you want a web page that not only sells the system to convert your Yamaha generator to try fuel system. But awnsers all and every question, such as fuel consumption, warranty issues, ext...
Yamaha Propane and Natural Gas Generators
I did the switch to my EF2800iC...
I found that it ran better, sounds more quiet, works better over 9,000 feet.(live and play in colorado).. The amazing thing is when I change the oil how much cleaner it is... not black like when it ran on gasoline.. also It does not smell as bad as gasoline when running...(it maybe more cleaner, I would myself like to know the question to that)
The sight also sells try fuel generators! knowing what I know now, would never buy just a gasoline generator!
Also one last point I also purchased a remote start system... It is a must with a generator...
As for the do it your selfer... I would rank it 5 out of 10... You do need a drill if you want the try fuel, if you just want propane, you do not need to drill. (do yourself a favor buy a brand new drill bit you only have one shot so you want it sharp, I started with a smaller bit and then redrilled with a larger bit two times... this makes sure the hole stays where i want it and does not bore to one side or the other)
todd@VINTSREAM.com
vinstream is offline   Reply With Quote
Old 09-05-2008, 10:26 AM   #4
Does anyone know how to communicate with US Carburetion? The email address they list, tech@uscarb.com , doesn't work and the phone numbers are never answered. I have sent two web form questions that have never been answered.
Barry
pattonsr is offline   Reply With Quote
Old 09-05-2008, 11:37 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Barry
I got a pre-built LP 1000 watt Yamaha from them. They are beyond disorganized and nearly unreachable. The product is high quality as is the conversion, but I think you've found the one sore spot, even 2-3 years since the purchase that I still clearly recall I had an issue with.....
Old 09-05-2008, 11:57 AM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Originally Posted by Silvertwinkie View Post
..... They are beyond disorganized and nearly unreachable. The product is high quality as is the conversion, but I think you've found the one sore spot, even 2-3 years since the purchase that I still clearly recall I had an issue with.....
Ditto
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-06-2008, 09:23 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
And re-ditto. I purchased my 2400 from them and had them do the conversion. Great quality work, never a problem with the unit. Communication however was, um, spare.
Pat
pmclemore is offline   Reply With Quote
Old 09-06-2008, 05:16 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No communication??
Wow..converted my Honda 2000i last Spring, only had to make 2 phone calls, but had no problems. Sounds like things have changed.
But all are right, it is a great conversion, went with the dual mode.
It does work great, on gas and LPG. Seem's quieter too, with a lot less combustion odor.
Pretty straightforward install, just read the pamphlet, get used to the terminolgy. When I did mine they had me send the carb to them for the mod's. Guess to many were having trouble with it.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
My propane Yamaha Generator from US Carburetion TitusLivy Generators & Solar Power 87 12-26-2011 11:01 AM
Yamaha EF3000iSEB davidz71 Generators & Solar Power 27 12-24-2006 11:25 PM
Yamaha EF2800i bhayden Generators & Solar Power 13 12-23-2006 01:46 PM
Yamaha Generators, again... Tavis76 Generators & Solar Power 63 10-17-2006 07:21 PM
Yamaha Generators Bilouie Generators & Solar Power 27 04-23-2006 04:14 PM
