Old 09-18-2011, 11:26 AM   #1
san diego , California
YAHAMA 2400 help with pictures please! TRI FUEL CONVERSION!!!
I need a little help here with pictures please
I just got my kit for my 2400! The instructions were a little bad. Anyone have some picture of the install? Any videos for the 2400? Do you have to cut out a hole for the hose? Where is the best place to mount the reg on the panel?
Thanks for your help
Doug
sandiegoguy is offline   Reply With Quote
Old 09-20-2011, 11:08 PM   #2
New Valve install.
Old 09-20-2011, 11:28 PM   #3
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I have the 2400 as well and want to convert it to propane.
Who did you buy your kit from?
Did you get it installed and running?
Any tips?
Thanks, MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-21-2011, 08:38 AM   #4
Any tips?
Thanks, MarkR
Hello mark,
Yes I got it from us carb, You can also get them from eBay. I just broke the engine in on gas yesterday! You have to run a tank of gas first to break and seat the rings! Check out the other thread on this fourm. Also you need to put a valve in like I did! The instruction for the kit suck but with the help on this sight you can figure it out! It is a great generator!
Good luck and if you need any help just email me and pictures do help out and I think I will put up a youtube video of my 2400!
I traded in my carb so they sent me a new one that was already drilled and all I had to do was swap it on the generator. Easy to install. You can do it!
Good luck
Doug
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
GMC Conversion Van Test Tow JitneyBead Tow Vehicles 3 07-17-2011 11:25 PM
Extra fuel tank line? pdallas Classic Motorhomes 4 05-12-2011 09:32 AM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
