03-22-2018, 12:35 AM
Journeyman
2016 25' International
Amherst
, Massachusetts
Y connecters vs. Combiner Box
All,
I'm prepping for a solar install in April and researching it to death.
Most people seem to use combiner boxes, but Renogy kits just use a series of MC4 Y connectors to get from all the panels to just a pair of conductors heading down into the trailer.
There's something appealing to me about the Y connectors since it makes the system totally modular (I could pull off a panel just by disconnecting a Y rather than opening up a box... no tools needed ) but I'm not sure of any downsides.
Any thoughts on this?
03-22-2018, 06:45 AM
2007 22' International CCD
Corona
I’m doing both. Existing panel is in combiner, the two I’m adding will use MC-4 connectors then one set of wires into combiner that is already on roof. There are several other wires for antennas that I pass through the box for convenience. One hole, multiple uses....but I’m running out of places to put the cable glands. I’d love a much bigger box but I’ll run with what I have for now. Gets crowded in there[emoji18]
03-24-2018, 03:47 PM
2022 25' Flying Cloud
NCR
, Ontario
i got these off amazon
10 pack male/email pair with pins for $14
03-24-2018, 03:59 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I used MC4-Y connectors
03-24-2018, 04:00 PM
Overkill Specialist
Dadeville
, Alabama
How many watts are you adding.
03-24-2018, 05:39 PM
Journeyman
Amherst
, Massachusetts
400 watts
03-24-2018, 06:23 PM
Overkill Specialist
Dadeville
, Alabama
Originally Posted by thiel
400 watts
I would go with a combiner box for four panels. I just used 2 panels on my install and that’s way I used the MC4-Ys on mine.
03-24-2018, 07:52 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
For 2 panels, why did you not just wire them in series? No Y connector needed.
Dan
03-24-2018, 08:52 PM
Overkill Specialist
Dadeville
, Alabama
Dan
Because parallel is the way to go. Better overall results and out put with the whole system not going down due to shadows.
03-25-2018, 12:31 AM
2018 25' Flying Cloud
Portland
, Oregon
There are these 4-way cables as well. I’ll use a combiner box on mine since it will be 500watts.
04-15-2018, 10:47 PM
Journeyman
Amherst
, Massachusetts
I discovered a detail here: MC4 connectors are designed for 10 gauge wire or smaller. I had hoped to step up to 6 awg as soon as possible to preserve voltage... and that means I can't really use MC4s for my entire run.
SO... I have to run 10 awg MC4 connected wires to a combiner box, then run the 6awg out of the combiner.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Roof Hole for combiner box
wponder |
Electrical - Systems, Generators, Batteries & Solar |
15 |
03-25-2018 12:24 AM |
Solar Panel Combiner Box
davidz71 |
Generators & Solar Power |
4 |
05-26-2007 11:52 AM |
