06-08-2011, 05:29 PM
2011 23' Flying Cloud
Flagstaff
Worth $2600 for the Airstream solar system?
We are looking into a Flying Cloud but the one we want is $2600 more with the 53W solar panel, 2 Glassmat batteries, and charging panel. How reasonable is the price of this add-on? If I wanted to add one later, I would have to hire someone to do it and it may be hard to get that done in Arizona. No dealers stock Airstreams but they will do service and special orders.
06-08-2011, 05:38 PM
Silver Mist
Riverhead
, New York
It is high, the install takes about 4-5 hours, parts under $1,000.
06-08-2011, 06:03 PM
Naples
You can buy lot more solar than 53 watts for $2300. Look here: Welcome to AM Solar_Your RV Solar Specialists since 1987
lewster
06-08-2011, 06:36 PM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
RV Solar Kits : WeGo Solar, Wind and Microhydro for Canada
$699.00 Canadian dollars + installation for a 125 watt RV system (assumes your RV has batteries already). There are likely U.S.A. distributors for HES systems as well. I'm putting this 125 watt system in our 1977 Tradewind this summer.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
06-08-2011, 06:56 PM
Silver Mist
Riverhead
, New York
One of the guys in my unit wrote this up is it helps.
Let me say, first off, I'm no expert. I received help. So here's what I installed:
(2) Uni-Solar Solar Laminate 68W PVL-68 panels
(1) Blue Sky Solar Boost 2000E controller
(1) MC3 Branch Connector, 2 Female/1 Male
(1) MC3 Branch Connector, 1 Female/2 Male
(1) 15' MC 3 Solar Panel USE-2 Cable, 10 AWG
The solar panels (9'4"x 16") were installed, one on the front RS and one on the rear CS roof. The panels are flexible and adhere with a peel-and-stick method. They will bend over curves, such as the end caps, but won't take a compound bend. The Uni-Solar panels come with about 1 1/2' of cable with MC3 waterproof fittings (one male and one female) attached. The panels were placed so that the cables from both panels came together just in front of the AC unit. From here I used the MC3 branch connectors to connect the like charged cables in parallel. The 15' MC 3 cable comes with one male connector and one female connector. I cut this cable in half and had two 7 1/2' cables, one male and one female. These cables go from the branch connectors, across the roof, through the refrigerator vent to the Solar Boost controller. Depending on where one places the controller, they may need more or less than 15' of cable. (For example, in Jerry's trailer there is a pre-wired lead from the bottom of the fridge compartment to a point in the galley where the controller will be mounted.) He will more than likely need more than 15' of cable to get to the floor. From the controller, in my unit, a short pair of wires go to the floor of the fridge compartment where they meet a pre-wired pair that go forward to the battery bus bars. The positive wire gets a 30 amp fuse just before the bus bar.
My system appears to be working well. The cool thing about the Solar Boost controller is that it converts the excess voltage coming from the panels to increased amperage going to the batteries. For example, the other day 3.6 amps were coming from the panels and 4.9 amps were going to the batteries. It's "magic".
I got the following from Akarienergy.biz.
Qty | Item # | Description | Price Each | Total Price
1 | PVL-68 | Uni-Solar Solar Laminate 68W PVL-68 | 209.95 | 209.95
1 | 32.0009UR | MC3 Branch Connector, 2 Female/1 Male, | 15.65 | 15.65
| 32.0009UR
1 | 32.0008UR | MC3 Branch Connector, 1 Female/2 Male, | 15.88 | 15.88
| 32.0008UR
1 | USE2Cable15 | 15' MC 3 Solar Panel USE-2 Cable, 10 AWG, | 22.60 | 22.60
| 600VDC
Subtotal 264.08
Tax 0.00
Shipping (Ship with Flat Rate UPS Ground (U.S. ONLY)) & Handling 17.00
Balance Due 281.08
Akarienergy.biz has the Blue Sky Soler Boost 2000E for $249. It's not on their site, but you can get it through them by ordering on the phone. It's not clear what the additional shipping will be. I searched the web and found the following offers for the Solar Boost 2000E:
pvpower.com $245.49
infinigi.com 239.69
simpleray.com 251.78
affordable-solar.com 248.00
altestore.com 253.88 (all of these prices include shipping to my zipcode)
06-08-2011, 07:05 PM
Wise Elder
2010 30' Classic
South of the river
The Airstream-supplied setup is widely considered to be not only overpriced but too small for any practical use other than battery maintenance during storage.
Most RV solar installs are in the 200-300 watt range and up.
06-08-2011, 09:07 PM
Maniacal Engineer
Lopez Island
I installed 200W of solar power on our 72 Tradewind from AM Solar this spring.... came to about $1350 delivered. It has worked flawlessly so far; keeps batteries (dual group 27s we already had) full in rain, snow and even sunshine. We have converted to LED lights in anticipation of this so our power requirements are low (water pump, my CPAP machine, lights, fans, inverter for LED outside lights, etc.). I do plan to add a small 12V sound system... the tracking controller does a great job; its very impressive to see several amps of charging current on cloudy overcast days. I also have a Trimetric battery monitor which I strongly recommend; the integrating ammeter feature really lets one track overall battery state accurately.
We don't have AGMs... but w/ a solar rig, unless you're really hammering the batteries, the need for resilience in the face of repeated deep discharges is much reduced.
We'll get some good testing in @Juplaya and Burning Man this year; we hope to spend some time camping in the national parks soon.
- Bart
10-14-2011, 04:30 PM
2010 27' FB Classic
N/A
I have the AS solar panels that were installed on my trailer when it was made in 2010. I recently used the trailer at the Balloon Fiesta in the NM sun and things went like this:
Started out at 100% first day. By night the batteries were still at 100%. even with the 2 roof fans running all day.
The next morning after using stuff like some lights and the water pump and fans at night. The batteries were down to 65% by 10 am. That afternoon the batteries recharged 100% and that was while still using fans when needed. Same thing for several days, over and over. They work for me just as advertised.
One afternoon I did hook up my Yamaha generator but that was only to run my air conditioner for an hour or so. I didn't need to use the gen to recharge the batteries at all.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
10-14-2011, 06:15 PM
2012 25' Flying Cloud
Battle Lake
We got the factory solar on our new trailer because that's the way this trailer was ordered by the dealer for their inventory. I didn't want it because of cost, but believe I was able to negotiate that option near dealer cost, because it was already there.
Love it. Nicely installed, wired during build, convenient control/indicators. My experience is the less my vehicles are in after-market/maintenance shops, the less chance of collateral damage. If you know someone skilled at installing solar in Airstreams, fine. If not, get the factory option.
doug k
10-14-2011, 07:26 PM
Port Orchard
Monetarily, it is not a good deal. So it is a matter of how much your time and trouble is worth to you. We ordered our trailer and got the factory panels. I knew when we ordered it that I could get it done much cheaper after market. However to me the it was worth the extra to have a standard factory installation with the same warranty as the rest of the trailer.
Ken
11-15-2011, 07:14 AM
Hedonistic Bohemian
2007 27' Safari FB SE
Atlanta
, Georgia
I have purchased two Grape Solar 100 watt panels and a SunSaver MPPT 15A charge controller for installation on my 2007 Safari 27FB. I expect to install them myself, hopefully over the next 4 weeks while I have access to a well equipped shop.
I'm concerned about at least two things:
- mounting securely on top of the Airstream
- running the wiring from up top
I plan to build two angle aluminum mounting frames with a key & key-hole system that will allow me to remove the panels for security and occasional tilting on some ground setup, but I still have to mount the mounting frame. I've never drilled a hole in my Airstream, and it's a little scary.
My Airstream has "solar prewire". Whatever that means. Where would those wires be up top?
Helpful thoughts appreciated.
11-15-2011, 07:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
NO...
11-22-2011, 03:25 PM
1987 32' Excella
Nepean
, Ontario
Scubadog, the best place to scope out solar deals is in Quartzsite AZ - one day drive from Flagstaff. Last year I saw several vendors of solar stuff there.
As for what you may need, in my '94 LY motorhome, I had a 123-watt panel but only 2 wet cell batteries. I can tell you that it was not really enough storage, and I planned to add 4 more batteries. Then I came across a deal and sold the motorhome and bought a 1987 32-foot Excella that came with: 3 75-watt solar panels, 4 AGM batteries and a 1400-VA Xantrex inverter/charger. The guy I bought this from had had this installed in Lake Havasu City AZ back in 2003 for $4,300.
If you plan on boondocking, you will find that 4 AGM batteries is comfortable. There are those who go nuts for this type of stuff - I recall meeting up with a guy in a SOB Class A who had a rack of 24 AGM batteries and something like 12 120-watt solar panels on lifts so he could align them for maximum efficiency. He was able to run his two roof airconditioners off the batteries. I admit that this is gross overkill, but a minimum 120-watts solar panel is what you should look for. As for batteries, 4 AGMs are nice.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
12-26-2011, 05:37 PM
1978 29' Ambassador
Albuquerque
, New Mexico
I agree with a previous poster - if you are ordering your AS new, there is value in having the wiring etc. done during assembly. But that is a tiny system!!
Sounds exorbitant to me.
12-26-2011, 05:47 PM
Oasis RV in Tucson is a former Airstream dealer and still maintains a service department working on lots of Airstreams.
They have installed many solar power systems.
While not exactly cheap, I am sure they could considerably better the factory price.
You might call them for a price. Lots of room for people to stay in their trailers, hooked up to electricity, if work takes more than a day.
10-12-2012, 11:53 PM
2012 25' FB Flying Cloud
Minden
, Nevada
The wiring for a solar system is included in the $50,000 to $110,000 we pay for these things. I know! It's really just a wire that goes from the roof down the refrigerator vent opening and down to a dark spot above the refrigerator, all included with a smile.
The $2,600 the factory charges for a beginner's solar panel is criminal - do not buy it. Your dealer can install just about any solar system you want. My dealer, Sutton RV, installed a 180 watt dual panel system with a charge controller for less than $2,000. I'm absolutely happy with the system I have. Airstream is just as out of touch with a reasonable solar package as they are with modern insulation and plain old quality control.
Russ
10-13-2012, 08:06 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
1000 watt gen cost about $700 and works when the sun does not shine.
10-13-2012, 12:01 PM
one of those
2011 27 FB International
'03 F250 PSD
, Airstream summers, Catalac winters
I could be wrong, but these days I think you can get 2KW for that.
10-13-2012, 12:22 PM
1999 27' Safari
Palo Alto
I just self-installed a 288 watt system for about $700 in parts, before the 30% federal tax credit.
Two Unisolar ePVL 144 panels (144 watts each) off of ebay for about $300 shipped.
One Intronics MPPT charge controller for $200 shipped.
A second RV battery from Costco for $100. AGM batteries would of course cost a lot more.
Roughly $100 of copper wire and connectors to hook everything up.
Because the Unisolar panels are peel and stick, I didn't need to purchase any mounting hardware. Also, because Unisolar went bankrupt and liquidated, the panels are currently relatively inexpensive - just about $1 per watt - but you get no warranty and it's clearly buyer beware. Last - two Unisolar panels wired in series put out 90 volts DC - so you don't need to run expensive heavy gauge copper wiring to avoid voltage drop like you do with 12 volt DC nominal panels.
My complete system came out at $2.43 per watt for 288 watts. The Airstream system you described appears to price out at $49 per watt for 53 watts - 20 times more expensive per watt.
In any case I hope these numbers help you get an idea of idea of of a floor of price per watt to shoot for coming from an el-cheapo DIY guy.
- Dan
1999 27' Airstream Safari + 2011 Mercedes GL 350 Turbo-diesel + 2021 Ford F150 Platinum Hybrid w/ 7,200 Watt Pro Power
10-13-2012, 07:24 PM
2010 27' FB International
Bend
, Oregon
I would really like to know more about your experiences with the peel and stick Unisolar panels. Can you tell if they seem to have the output their specs show? How sensitive are they to direction and intensity of the sun. Do they work well on cloudy days?
How well does the peel and stick adhere to your roof? Would it be a major problem to remove it if stopped working or had other problems?
Thanks, Steve
