Old 03-19-2013, 11:10 AM   #1
Libo's Avatar
2010 31' Classic
Crestview , Florida
Wiring through the Fridge vent. HELP!
We have a 2010 31' and we have a solar prewire running from under the sofa to the fridge box outside.
HOW do we run the wire from the panel through the fridge vent? The top of the vent has a screen, we drilled a small hole on the side and threaded a wire with a weight and it's hitting something on the way down.
What can we do? Any suggestions or photos would be helpful.
Airstream's tech support is nothing but an answering machine. Didn't help me much.
Libo is offline   Reply With Quote
Old 03-19-2013, 11:19 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
You can try to continue to "fish" the wire down. The area behind the refer is more or less open, but the piping and cooling system of the refer is there.
One can reach a quite a ways back up from the bottom.
Your other options are to drill the rivets and remove roof vent completely, which is not as bad as it sounds.
Or, slide the refer out of the cabinet.
I added an antenna to my roof, and chose to remove the roof vent. I had olympic rivets and termpro 635 sealer on hand, so just drill the heads off the rivets, remove the vent and complete your wiring and then era-attach the vent and seal.
Jeff & Cindy
jdalrymple is offline   Reply With Quote
Old 03-19-2013, 07:51 PM   #3
steverino's Avatar
2018 30' Classic
Ivins , Utah
Yes, there's a lot of tubes and screens on the back of the refr to capture the fishtape on the way down. I drilled out the rivets to remove the vent, and a couple more which secure the screen. Peeled the screen back a couple inches, and it was easy to drop the wire down close to the interior wall of the unit. An inexpensive pop rivet gun, aluminum rivets, and some butyl rubber tape and sealer from the hardware store is all you need to reinstall the vent.
steverino is offline   Reply With Quote
Old 03-19-2013, 09:16 PM   #4
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Libo,
take a trip to the hardware store, and buy a two or three feet of #3 or #6 size ball chain with couplings to tie a string to.
fish it down from the vent opening - the slipperiness of the chain and the flexibility of the string should get you past things.... gravity will be your friend!
a flashlight and a small mirror will also help you see "up" the flue.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
jm2 is offline   Reply With Quote
Old 03-26-2013, 12:53 AM   #5
MtnCamper07's Avatar
1993 30' Excella
Salida , Colorado
If this worked for you, fine. But if it didn't you may want to use a real fishtape and not some chain or string. The tape has a bit of rigidity to it that will allow you to 'steer it' some in the direction that you want. This should allow you to work the wire behind the plaumbing on your fringe. Good luck
MtnCamper07 is offline   Reply With Quote
Old 03-26-2013, 01:21 AM   #6
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
I found that reaching up behind the fridge helped.... and I used some pretty stiff wire which found it's way down w/o too many problems.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 03-26-2013, 09:31 PM   #7
1994 30' Excella
Mississauga , Ontario
If you decide to remove the vent cover, I found the easiest and neatest way to remove the rivets is to use a sharp wood chisel to cut the heads off the rivets. Hold it firmly against the head of the rivet flush with the vent and strike gently with a hammer. With a drill you can slip off the rounded head of the rivet and do damage.
Al
Al and Jean
TAC ON-3
BigAl is offline   Reply With Quote
Old 03-26-2013, 11:18 PM   #8
Maniacal Engineer
barts's Avatar
When drilling out bucked rivets, center punch the rivet to start the hole accurately. Replacement rivets are typically 5/32 diameter to compensate for hole "growth".
- Bart
Bart Smaalders
Lopez Island, WA
Old 03-27-2013, 07:07 AM   #9
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Remove upper cabinet
In my 85 Sovereign I found it easier to remove the upper cabinet (4screws). This allowed me to snake the wire down through the vent to the top of the frig which was now exposed.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
