Old 12-27-2017, 05:57 PM   #1
chugchug's Avatar
2018 25' International
Belmont , California
Wiring of the Portable Solar Panel Plug
Anybody knows how the plug for a portable solar panel at the front of the trailer
near the battery box is wired? Is it directly to the battery?
It is not shown on the schematics.
chugchug is offline   Reply With Quote
Old 12-27-2017, 06:12 PM   #2
2018 19' Flying Cloud
Newport , Washington
Yes it is wired directly to the batteries. If you open up the battery box lid you can see the wires coming in.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 12-27-2017, 06:20 PM   #3
2007 22' International CCD
There should be a fuse close to the battery terminals to protect the wiring, IMHO...
Old 01-23-2018, 10:04 PM   #4
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
So there is no danger of overcharging with a portable solar panel if it's wired directly to the battery?
Old 01-23-2018, 10:33 PM   #5
2016 19ft flying cloud
Spokane , Washington
Not if you have a controller hooked in between panel and battery
Spinonedad is online now   Reply With Quote
Old 01-24-2018, 06:20 AM   #6
Hans627's Avatar
Which, of course, leads to another question. Is there a controller of some kind between the solar panel and the battery?
From the videos I have seen it is described as "plug and play". Just plug the solar panel into the receptacle and it will charge the battery. The video I am referring to is from Colonial Airstream describing the Globetrotter.
Old 01-24-2018, 06:27 AM   #7
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
The controllers on the portable solar panels are attached to the solar panel. Then there is a cable that plugs into the Zamp port on the side of the battery box.
billrector is offline   Reply With Quote
Old 01-24-2018, 11:32 PM   #8
Not all panels come with a controller
You must have one between the panel and the battery to regulate the voltage coming out of the panel
Old 01-25-2018, 12:24 AM   #9
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
I bought a water proof controller. It sites right next to the battery box when in use, with 30ft run to the panels. Works great.
Matti
Mattirs is offline   Reply With Quote
Old 01-26-2018, 08:40 AM   #10
Hans627's Avatar
At times I have my AS stored in a lot with no electrical service available. I am thinking that using a portable solar panel from time to time would keep the batteries topped off.
Would that make sense?
Old 01-26-2018, 09:48 AM   #11
chugchug's Avatar
With a decent controller you can just leave it plugged in.
Old 01-27-2018, 07:02 AM   #12
Hans627's Avatar
I guess my concern with keeping it plugged in would be someone walking off with it. Having it hooked up for a shorter period of time helps minimize the chances of that happening.
Doing some searching it seems like Zamp makes a portable unit. Is that what others are using successfully?
Thanks!
Old 01-27-2018, 08:32 AM   #13
2017 25' Flying Cloud
Raleigh , NC
I did the same thing as Matti. However, if you buy a non-Zamp panel, you have to reverse the solar plug connection cables on the battery posts. Zamp wires theirs ‘backwards’ of normal plugs so that they are not compatible with other units. Once you do that, you can also plug a battery maintainer into that port.
Matti
JoeHTP is offline   Reply With Quote
Old 01-27-2018, 02:01 PM   #14
Mattirs's Avatar
Joe, glad you brought up reversing the wires as they go onto the controller. The leads to the batteries are normal polarity and so, as Joe said, works great for plugging in a trickle charger.
Old 01-27-2018, 02:19 PM   #15
Mattirs's Avatar
ID:	303092Click image for larger version
ID:	303093 Just running a little load experiment in the driveway with winter light.
Matti
Old 01-28-2018, 08:05 AM   #16
Hans627's Avatar
Attachment 303092Attachment 303093 Just running a little load experiment in the driveway with winter light.
Matti
So the controller (Midnight Brat) is independent of the solar panels? Does it matter which solar panels you use?
And two panels such as shown in the picture produced how much electricity?
Thanks!
Old 01-28-2018, 09:14 AM   #17
chugchug's Avatar
Thanks!
There are multiple of options. I would use an MPPT (Maximum Power Point Tracking) controller as they are 20-30% more efficient then the PWM (Pulse Width Modulation). The panels should be rated at anywhere from 18-22V Open. I use an HQST MPPT controller which seem to be sold under several different brand names. The rating on the panels are sometimes confusing. They sometime rate the open voltage (18-22V) but other rate the intent application voltage (12V-24V) which is really the battery they intent to charge.
If you look at this Amazon page
https://www.amazon.com/dp/B018BMGTTO...d_w=xLlaJ&th=1
They talk about 12V panel, but the open voltage is 22.5V. It will work fine with the MPPT controller to charge your 12 V battery.
Old 01-28-2018, 10:57 PM   #18
Mattirs's Avatar
Thanks!
The panels cannot put out more than 18 volts and at least at least be called 12 volt panels. To really charge your batteries the panels need to put out over 15 volts. That is what the controller does is regulate to have the proper voltage and amp flow needed to charge the batteries fully and safely.
All components were bought separately as they came on sale. (Thrifty Finn here) The Midnite Brat PWM controller is sufficient for the two 100 watt panels that I am powering the system with. In full sunshine and a low battery level it puts out a little over 7.5 amps. It takes about 7 hours of good sunlight to recharge my batteries to 100% from a 45amp (60%)draw down.
I use 30 feet of 10awg wire between the panels and the controller, and between the controller is only 1.5 feet of wire. This results in very little voltage drop, keeping the system pretty efficient. There is a lot to learn about building an efficient solar system.
I got the controller for around $80 on sale, so for me the extra $125 was not worth the extra 1.5 amps it would gave squeezed out. Now if I had 600 watts or more the amps gained due to the efficiency of a MPPT controller is equal to the cost of a panel. MPPT controllers take the higher 17 volts put out by the panels and convert it all to amps. Where as PWM controllers loose the difference between the 17 volts the panels put out and the 14.4 volts the batteries are wanting. This where MPPT is more efficient than PWM.
Matti
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 05:35 PM
Recommendations for portable solar panel kit? jagzoo Generators & Solar Power 37 03-06-2017 09:28 PM
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 04:28 PM
Portable solar panel table timzog Generators & Solar Power 7 01-29-2016 03:39 PM
Portable Solar Panel Battery Charger Mrjkq Electrical - Systems, Generators, Batteries & Solar 10 08-09-2015 09:22 AM
