Old 06-15-2010, 12:26 PM   #1
billiards's Avatar
rochester , Minnesota
wiring help/solar
i thought it would be a piece of cake....having after a year of manuel moving solar panel at ground level ...decided to mount it on roof (2005 safari 25 ft.) , forum threads have from time to time mention the option of running the wire from the panel over and down refrig. vent.....it seems that it is not a wide open free fall from vent cover, has anyone done this that can give me tips on this or a better option?
billiards is offline   Reply With Quote
Old 10-07-2010, 05:43 PM   #2
Billiards, having the same problem, I started looking and found your thread. I sure wish someone had replied. Did you solve the problem and can you shared it with me?
farreach is offline   Reply With Quote
Old 10-09-2010, 12:10 AM   #3
Santa Cruz , California
Images: 12
Having done this in a Tradewind and more recently in a 310 motorhome, yes it is not a wide open free fall because (a) the wall is curved and (b) the refrigerator is in the way. I had to pull the refrigerator out a few inches so I could get to the wire end. I wanted to use a regular electrical fish tape but would have had to take the refrig vent cover off, that seemed more trouble than it was worth. Use big stiff wire (I used #10 stranded). And be sure you fix the pieces of vent screen that you bent or cut to pass the wire through... you want to keep the wasps out...
dljosephson is offline   Reply With Quote
Old 10-09-2010, 07:32 AM   #4
Thanks DL, right now I'm stuck at the screen at the top of the vent. Until your post I didn't know it was a screen, just knew there was an obstruction there. I can't even get my fingers in there to touch the screen. I'll try again, new day - new determination.
Old 10-09-2010, 11:01 AM   #5
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
Pine Valley , California
Images: 141
All,
Try Eheffa and my install options for your coach. Evan has quite a detailed install for two pannels as do I on http://www.airforums.com/forums/f448...ort-62608.html
My install starts on post #69 on page 5 of this thread. Hope it gives you ideas and an option for the refer vent install...
Love ours, no leaks, no problems.
Stream Safe,
Bob U-
Pine Valley, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Solar Wiring 09 22FB Sport oldirty Generators & Solar Power 1 06-29-2009 02:22 PM
Best way to go solar? flynmike Generators & Solar Power 11 05-23-2006 06:01 AM
solar wiring walter1 Generators & Solar Power 3 09-14-2004 03:13 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
solar 4 our AS lee Generators & Solar Power 10 07-05-2003 06:19 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
