Old 06-20-2008, 12:10 PM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I found these two at the Costco site
Costco - Whisper 100 900 Watt Wind Generator
Costco - Air X 400 Watt Wind Turbine
Richard
Old 06-20-2008, 01:29 PM   #16
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Originally Posted by Dwight View Post
The one downside to using wind or solar, is you usually don't have a means to store the energy (batteries) that is created. When the wind quits or it is dark, the energy stops.
We have 4~120 panels and 8~batteries and can run the 15k AC for almost 6 hours. We wouldn't be able to do that if I didn't have the batteries to store the energy.
Dwight has a very telling point. When we need solar the most is in the middle of the blooming blizzards endemic to Maine winters... no (significant) solar ergs available, then! That is when wind would be valuable for me -- but I'm running a furnace and a catalytic heater at that point and sucking the batteries dry. Under those conditions, many (most?) wind generators are feathering their blades to prevent overspeed damage so you aren't getting a whole heck of a lot of value out of that excess wind. I'd be in deep trouble unless I had access to shore power. So make that a power pole for me in winter - or at least a job site somewhere south of Atlanta...
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 06-20-2008, 01:45 PM   #17
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Solar comment
It is 2:38 p.m., overcast to the point that I cannot tell where the sun is right now AND the PulseTech 5 watt solar panel for the Everlast battery I pulled out of the Sovereign 5-6 months ago shows a constant charge. I checked the charger on the Sovereign and the two 100 watt panels and one 65 watt panel show charging through the Heliotrope 22B charger as charging the Trojan battery.
Where do people get the idea that solar panels don't put out energy when the sun is behind clouds? Sure, the same amount of power is not there as when the sky is clear but energy is there, overcast or not. I know that my AMSolar SunRunner system is an advanced system with 44 cells per panel and the charger is a boost charger but don't discount solar based on old systems.
OK Lewster, carry on with the argument.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
davidz71 is online now   Reply With Quote
Old 06-20-2008, 01:59 PM   #18
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
My first Safari had solar. I could have discharged batteries(2), and recharge fully on a cloudy day. Sure it took longer than direct sun, but still effective.
I bought the unit with solar already installed, I don't know the specs.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-20-2008, 03:54 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
The problem with most of the solar charging system out there are:
1: poor quality to sell at a cheap price point
2: cheaply made collector panels to sell at a cheap price point
3: relatively innefective solar charge controllers to sell at a cheap price point
(are you getting the message yet??????????????)
4: substandard wiring (smaller wire guage) to (.......fill in the blanks!!)
YOU GET WHAT YOU PAY FOR!!!!
In the AM Solar Sunrunner systems, we use a minimum of 10 gauge wire for connecting the panels, and 8 gauge to connect the array to the controller.
And yes!....the panels do work on cloudy, overcast days. Not up to the voltage output of sunny days, but still useable and still charging your batteries.
Comments???? QUESTIONS??????
Old 06-20-2008, 04:11 PM   #20
richinny's Avatar
2011 34' Classic
Originally Posted by mandolindave View Post
Wind turbines wanted to see wind speeds in excess of 12 miles per hour.
i guess this would do a great job of charging while towing!
Ricky
Old 06-20-2008, 04:20 PM   #21
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I'd like a small nuclear reactor. Bet it would be quiet too.
When we camp the juice flows. AC, TV's, microwave, coffee pot, blow dryer, flat iron, stereo, party lights. Gave up the tent quality camping a long time ago.
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 06-21-2008, 06:37 AM   #22
jzelle's Avatar
2006 28' Safari SE
Halifax , Nova Scotia, CANADA
Ther's also the "noise" angle
Even small wind generators are quite noisy, your neighbors might not appreciate it.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 06-21-2008, 08:15 AM   #23
Images: 59
. . . but until then, I'd like to have a reformer and a stack of fuel cells.
Old 06-21-2008, 08:18 AM   #24
2007 25' Classic
Hydes
The Air-X is on it's third incrarnation with much lower noise levels. There are other small wind generators used mainly Wind Generators Kiss High-Output Wind Generator for sailboats that could be adapted to RVing
craftsman is offline   Reply With Quote
Old 06-21-2008, 11:08 AM   #25
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Originally Posted by overlander63 View Post
Uhh...I did a search on "wind", and for some reason, I got search results for burrito fixin's...
Could it be an add for wind generator fuel?
Pop Rivet is offline   Reply With Quote
Old 06-22-2008, 07:11 AM   #26
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I've been thinking, and, if money were not so much an object, is there a reason you couldn't use both solar and wind power generation? My experience has been that on cloudy days, when there is less light for the solar panels, it tends to be windy.
Old 06-23-2008, 07:33 AM   #27
2004 28' International CCD
Rothbury , Michigan
Hi, All:
Thanks for all your responses (even the burrito one!). It's looking like everyone agrees that wind is nice, but as added to solar; and then on top of that, have a small generator for backup. Quite a pricetag, but given that i want to boondock more than not, it seems like it might be the ticket. Again, thanks for the advice.
i'll be doing more research on both wind and solar generation.
chandles is offline   Reply With Quote
Old 06-23-2008, 03:38 PM   #28
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I am enjoying reading this also. As I see our trailer as being an alternative home if a hurricane or other destroys our house in this city -- and we are living "elsewhere" for 9-18 months during rebuilding -- it would seem that a combination of sources is practical (beyond initial cost). Hope to see more.
