Old 02-02-2007, 05:48 PM   #15
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
I talked with AS today and the rep for the solar collectors said that if ANY part of the panel is in the shade, it decreases the amount of current produced dramatically. Even having the TV antenna shadow will across the cells stops current like a on/off switch. Interesting as I thought that if you had 80% sunlight you got 80% power. Not the case. If an antenna falls across the middle of the panel, it cuts the power in half. In other words, don't put the panels under trees.
altamont is offline   Reply With Quote
Old 02-02-2007, 07:35 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The type of panel also comes into play here. Amorphous panels are only 6-8 % efficient while Polycrystalline and Monocrystalline panels are both 12-14% effecient. What I have learned from some research is that you need at least the 36 cell panel and 44 cell panels are even better because they are putting out 21.5 volts straight from the panel. Panels drop several volts when they are hot according to what I have read so anything over 17 volts out of the panel should do the trick. Wire size also affects voltage drop.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-03-2007, 08:10 AM   #17
Happy Trails
bhunt's Avatar
2005 16' International CCD
Delaware , Ohio
Zugbug,
Do you do anything to prevent theft of the panel? Has 85 watts been enough for your lifestyle in a 19' Bambi?
bhunt is offline   Reply With Quote
Old 02-05-2007, 08:48 AM   #18
Zugbug's Avatar
Volcano , California
I haven't done anything to lock up the panel. but I am not normally away from the trailer for more than 5 or 6 hours at a strech. This is something I may need to consider depending on the place I am camped.
As far as power I have run for 3 or 4 days and kept my single battery at full charge the whole time. This is with using the DVD TV part of the time too.
Zugbug
Zugbug is offline   Reply With Quote
Old 02-05-2007, 01:39 PM   #19
altamont's Avatar
Tracy , California
I bring a length of chain and a padlock to attach to a tree or the trailer. Better safe than sorry.
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Free Memberships at WBCCI smily WBCCI Forum 5 10-01-2002 05:54 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
