Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-06-2009, 08:38 PM   #1
1978 25' Tradewind
Walnut Creek , California
Which size Honda generator - eu2000 or eu3000?
I recently purchased a 1978 Trade Wind. I will be camping mostly where there are no electrical hookups but only for a few days at a time. The new marine batteries should power my lights and water pump throughout these short trips.
I am interested in purchasing a Honda generator to run the 13,500 BTU air conditioner during the summer and as a general on board power backup. I am quite partial to Honda generators so for the purpose of this thread, I will be referring only to the two models for which I am trying to decide; eu2000i and eu3000i. The price and weight differences between these two models is almost double. An extra $1,000 and an extra 80 lbs.
The Honda website states that only the eu3000 is large enough to power our AC but I have heard stores from a reputable source that the eu2000 can power this AC alone.
So to my questions: Will the eu2000i power my AC unit? Is this an adequate size for my minimal needs or must I upgrade?
Thank you in advance for your feedback.
Lufetarg is offline   Reply With Quote
Old 04-06-2009, 09:49 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use two Eu2000's in tandem to run our A/C unit. A single 2000 will not handle the A/C. A single 3000 will also do the job, but it's pretty heavy. I like the versatility of the two 2000's. If we're not using the air, I can use a single 2000. These work very well for us. We use a 6 gallon auxiliary fuel tank the feed them.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 04-07-2009, 03:43 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Brian
This is my system also. IMHO the best way to go, you always have a backup. With a single generator you have no backup if something goes wrong.
Aaron
WBCCI #XXXX AIR #2495
Old 04-07-2009, 04:51 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think mostly because it can idle more and run slower in most circumstances, the 3000 is incredibly quiet. Noticeably more quiet than a 2000 (which doesn't exactly scream). But you do need to consider where you can transport it.
Old 04-07-2009, 05:49 AM   #5
Refurbished 89 Excella
DKDarrow's Avatar
1988 29' Excella
Sugar Valley , Georgia
There are several reasons to go with the 3000. We probably have 800 hours on the one we use to power our Excella. It runs a 15K heat pump/AC with NO problems. TV, computers for video editing, and even a hair dryer running cause NO issues. Kicking in the microwave which is a big one causes a problem; but for us is seldom used so we just turn off the heat pump/AC for that time without turning off anything else.
Yes, it is quieter to run a 3000, actually less gas than running 2 2000's, no wiring hassels having to bridge the 2 units, more to carry for the 2 units, on and on.
Yes, the 3000 is heavier. It's all kind of relative and just another problem to solve. Finding somebody to help tote it is my usual trick. Wheels, a ramp, and for some a winch to get it in and out of the truck is used by some. For me, I often just leave it in the truck with the camper shell and run it from there.
Whatever you do...............CHAIN it to something permanent when it is in sight by anyone. We use a motion detector alarm on ours which has saved it at least twice that I know of at 2AM.................
God Bless..........Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 04-21-2009, 12:51 AM   #6
2010 27' FB Classic
N/A , Texas
Dennis,
Can you supply us with some info on the motion sensor you use? Maybe a site and part number or name? I'm looking into ways to prevent theft of my 2 generators when I have to have them in the open at night. Also looking into some kind of screaming cable lock. Maybe a combination of the two deterents will be enough to give me time to wake up and address the problem when it happens.
Old 04-21-2009, 03:32 AM   #7
The Silver Schooner
Pudentane's Avatar
2007 28' Safari SE
Dover , New Hampshire
Yes, Please - info on the motion sensors and alarms. Thanks.
Louisa & Jasper Joy
Pudentane is offline   Reply With Quote
Old 04-21-2009, 04:25 AM   #8
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
If I may ask?
Originally Posted by Bluto View Post
Dennis,
Dennis..
Whatever info you might have to share, I would be thankful.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-21-2009, 09:03 AM   #9
2010 27' FB Classic
N/A , Texas
I also forgot to add some info I found which was for the alarm locks. The site is alarmlocks.com They have that screaming cable lock I mentioned above.
Old 04-21-2009, 10:29 AM   #10
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
The Honda website states that only the eu3000 is large enough to power our AC but I have heard stores from a reputable source that the eu2000i can power this AC alone.
The eu2000i runs our model Carrier Air V 13500 AC made in 2007 just fine. I too heard the same stories but became convinced when I saw the local Fire Department was using one to power the AC in their informational trailer. The outside temp was 98°, kids were in and out and the door left open, it ran without a quiver. Apparently the newer AC's have a more efficient starting system but older models are questionable.
Ahab is offline   Reply With Quote
Old 04-21-2009, 01:13 PM   #11
Wabbiteer's Avatar
Jupiter , Florida
IF you ever are camping at higher elevations remember the power output drops 3-4% per 1000' above sea level plus running rich w/ plug fouling, diluting piston/cylinder oil film & generally using more fuel than necessary starts happening above 3000 foot elevation...
Since the air gets thinner and there is less oxygen that 1600W rated (13.3A) resembles 1320w and 10.9A at Denver elevations and 1150w and 9.5A once you get up to 8,000 feet - then comes the running rich scenarios on top of that.
Yes its true you may not need AC at those elevations - just 'illuminating' another benefit of the 3000 vs.2000 models for a serious full-timer...
EDIT: re-jetting the carburetor to reduce the fuel flow rate at higher elevations for extended 'visits' (years?) is possible on both models, if you want to full-time above 4000 feet or so it'd be worth your time (remember $5 a gallon gas anyone?) ... but you MUST remember to replace original jets when you go back down hill!!
http://www.planopower.com/store/honda/eu2000i.shtml
http://www.planopower.com/store/honda/eu3000is.shtml
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 04-21-2009, 01:24 PM   #12
1976 31' Sovereign
Oswego , Illinois
When I go to alarmlocks.com comes up some financial redirect site nothing to do with locks, tried 4 times same result maybe some more info please. farmer bill
Old 04-21-2009, 01:30 PM   #13
Retired.
. , At Large
Alarm It Cable Locks
Old 04-21-2009, 02:13 PM   #14
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
We purchased the Eu3000....wish we opted for the 2 Eu2000's with the parallel. I think we have used the 3000 twice since purchasing it 3 years ago. It fires up the AC no problem. The thing is a bear to lug around.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 04-21-2009, 02:14 PM   #15
1976 25' Tradewind
Erie , Pennsylvania
Very interesting thread. I have been interested in purchasing a generator. I am curious if there are any other brands that the forums suggests. Also what is the price for a 2000 vs the 3000?
rollingbubel is offline   Reply With Quote
Old 04-21-2009, 03:56 PM   #16
1969 31' Sovereign
atlanta , Georgia
subscribing
I am also close to purchase and am between the 3000 + 2x2000 - If I can run from the bed of my truck mostly I'd be fine with the 3000.
J-
Atlanta, GA + Steamboat, CO
1969 31' Sovereign
https://www.klendesign.com
nunya001 is offline   Reply With Quote
Old 04-21-2009, 05:45 PM   #17
ts8501's Avatar
2022 25' International
Savage , Minnesota
Check out this thread. Includes Yamaha 2400 and 3000.
http://www.airforums.com/forums/f448...0-a-19725.html
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 04-22-2009, 08:30 AM   #18
2010 27' FB Classic
N/A , Texas
Originally Posted by overlander63 View Post
Thanks for giving the correct site info for everybody. I must have dozed off in the middle of posting.
Old 04-27-2009, 06:03 AM   #19
DKDarrow's Avatar
1988 29' Excella
Hey Guys.......SORRY for the delay in getting back about the wireless alarm system that we use.
The link is:
Dakota Alert. Wireless Alarms Security Equipment for the home, acreage, farm and business.
I cannot support these folks highly enough. Try to deal with the factory themselves as they are flat out great people. Honest and fair. Had to have one of our units repaired and they even updated it with NO problems.
For a a couple of years we used the 110V reciever with adapter for when we had hookups and a 12V to the required adapter when dry camping. NOW we have the:
Dakota Alert. Wireless Alarms Security Equipment for the home, acreage, farm and business. which works GREAT.
Placement of the transmitter box is painless. The biggest problem when doing this is figuring out where it wont pick up back ground movement. Most often now adays I just put it on the ground under the trailer pointed at the generator or the general area outside of the trailer.............Anyway, works for me with emphasis on WORKS............God Bless........Dennis
Dennis & Susan
Old 04-27-2009, 07:46 AM   #20
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
I just attended the Sun n Fun Airshow in Lakeland, Fl where Honda had a huge display of generators and other Honda equipment. They had on display a new 3000w inverter unit that weighs right at 50lb, max noise 58db and according to the rep on site the ability to run a 13500btu air conditioner. This case and controls are very similar, almost exactly, the same as the eu2000. However it does not have a starter and battery like the eu3000. The suggested retail price is $2100. They were selling the units at the airshow but I was told that mass distribution to dealers would not be until latter in the summer.
fltlevel510 is offline   Reply With Quote
Storage Container for Honda EU2000 generator? FOILED Generators & Solar Power 52 03-01-2018 05:33 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
LPG for Honda EU2000 moosetags Generators & Solar Power 35 10-19-2008 01:14 PM
Looking for a Honda EU2000 lundfog Generators & Solar Power 3 12-02-2005 06:10 PM
11,000 BTU AC and Honda EU2000 RangerJay Airstream Trailer Forums 34 10-03-2005 07:35 AM
