Old 09-08-2015, 10:08 AM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Which Sikaflex?
I just ordered Rocker mounting hardware for my solar panels from AM Solar. They told me that Sikaflex is used to reinforce the 3M mounting tape's adhesion. Looking online, there are several Sikaflex products. Which one should I purchase to add to the adhesion of the mounts?
bvcg1 is offline   Reply With Quote
Old 09-12-2015, 06:58 AM   #2
Jarrod White's Avatar
1966 28' Ambassador
Mobile , Alabama
I used sikiflex 221 based upon prior recommendations on this forum.
Jarrod White is offline   Reply With Quote
Old 05-16-2017, 11:41 AM   #3
Lily&Me's Avatar
Normal , Illinois
I'm going to have the caulk on my Interstate's roof scraped off and replaced in a couple of weeks, and need to order Silkaflex as the vendor does not carry it.
Is Silkaflex 221 what I want?
"Sika Sikaflex -221 Multi-Purpose Polyurethane Sealant Adhesive WHITE" ???
Thanks in advance.
Maggie
Old 05-16-2017, 01:07 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I just finished resealing my Overlander. Sikaflex 221 is my sealant of choice. I got it in gray from Amazon.
TheGreatleys is offline   Reply With Quote
Old 05-16-2017, 01:10 PM   #5
dznf0g's Avatar
Oswego , Illinois
221 here too, but, Maggie, isn't your van silver. Might want to consider gray...or aluminum I think they call it.
-Rich-
Old 05-16-2017, 01:13 PM   #6
Lily&Me's Avatar
Normal , Illinois
The sealant will go on the roof, which I think is white...tho I've never been on it, I'm pretty sure it is white.
Just been reading about adseal, as well, but I know that what's up there and has lasted 3 years is Silkaflex.
Thanks for any suggestions.
Maggie
Old 05-16-2017, 03:22 PM   #7
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
221 all the way!
Troutboy
Troutboy is offline   Reply With Quote
Old 05-16-2017, 03:43 PM   #8
Lily&Me's Avatar
Normal , Illinois
Okay, it sounds like 221 has the popular vote.
Thanks, all.
Maggie
Old 05-16-2017, 08:30 PM   #9
2016 25' International
Deerfield , Massachusetts
Don't forget your glue bottle condoms!
https://www.amazon.com/gp/product/B000H5S8XY/
thiel is offline   Reply With Quote
Old 05-22-2017, 09:00 PM   #10
Ayr , Ontario
221 has a very short shelf life so don't save it for a job next year. If you are using any tube of caulk and the spout has dried just cut along the length of the tip and remove the dried portion and then use electrical tape to tape it back together. You can get many more uses out of it that way.
gator.bigfoot is offline   Reply With Quote
Old 05-22-2017, 09:08 PM   #11
dznf0g's Avatar
Oswego , Illinois
I've kept 221 in the freezer for 2 years with no degradation in performance. I keep all my polyurethanes in the freezer. Open tubes with plastic over the open end keeps really well...just a small plug of cured sealer at the tip. Easily pulled out with a pick.
-Rich-
Old 05-24-2017, 11:07 AM   #12
Ayr , Ontario
My tube wasn't even open yet. But one year later the tube was solid. Waste of money. Perhaps it was just a fluke.
Sikaflex 1a sealant Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-22-2015 02:24 PM
Sikaflex at Home Depot? Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-14-2010 08:36 AM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 05:37 PM
Storing Vulkem or Sikaflex cameront120 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-30-2007 05:24 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
