Old 05-19-2019, 10:38 PM   #1
Boise , Idaho
Which Honda eu2200i to get
Ok so I want to pick up a Honda eu2200i generator this week. Im wondering, do I get the companion because it has the 30amp plug in? Or do I need to get the standard model and use an adapter?
James3344 is offline   Reply With Quote
Old 05-20-2019, 06:05 AM   #2
nryn's Avatar
2019 27' Globetrotter
Chicago area , Illinois
I have a companion (on propane). It lets me use the 30A cord as usual without dogbones. If I need a 120V outlet I use the ones in/on the Airstream after the generator is hooked up.
I guess it depends on what you want the generator for. If you want an all-purpose generator for use other than with your Airstream, get the normal one. If you want one mostly or strictly for camping with your trailer, get the companion. They will both work.
nryn is offline   Reply With Quote
Old 05-20-2019, 06:14 AM   #3
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
With purchase of the EU2200i companion and a special cable you can pair that unit to another regular EU2200i to double the power output. At that point the 30 amp outlet makes sense. The EU2200i companion alone outputs around 20 amps max, the 30 amp plug notwithstanding.
Unless you plan to purchase two of these generators save the extra $100 and just get the regular EU2200i. They are identical in every way except for the 30 amp plug.
kscherzi is offline   Reply With Quote
Old 05-20-2019, 04:04 PM   #4
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
I enjoy the 30 amp plug, seems more secure... Vinnie Airstream Repair is installing an Easy Start so I can run AC now and then, so the 30 plug works for me.
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 05-20-2019, 05:09 PM   #5
r carl's Avatar
Lin , Ne
I would get a camo one. Those red generators stick out like a sore thumb.
Old 05-29-2019, 03:45 PM   #6
GSansoucie's Avatar
2019 28' Flying Cloud
South Berwick , Maine
Wait, where are you able to buy an EU2200? All the places around here are still on hold for the recall (I've called around a few times).
Good thread though as I was wondering the same thing about the Companion for the 30A outlet to save an adapter (I realize it won't put out 30A)
GSansoucie is offline   Reply With Quote
Old 06-02-2019, 02:36 PM   #7
2017 20' Flying Cloud
Georgetown , Texas
Been trying to find out also. Dealer not clear I don't think I would order online without knowing with certainty though...
https://powerequipment.honda.com/sup...ls-and-updates
SYC2Vette is offline   Reply With Quote
Old 06-02-2019, 02:49 PM   #8
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Recall Kits Are Out There
Dealers have had the recall kits for awhile.
If the recall has been done, the OEM box has a green round sticker on it.
Kit # 06161-244-A30
The kit is a new fuel shut off valve and a cute sticker.
I saw one kit being installed today.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 06-02-2019, 03:23 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You wi have to use an adaptor to the 30 amp trailer with either of them. I think the 30 amp generator is a little more solid than the 15. Does the Companion have both the 30 and a 15? I use a Companion 2000 and never bought or needed the second generator.
Honda EU2200i vs EU200i Companion Bradley G Generators & Solar Power 18 06-04-2019 12:28 PM
Honda EU2200i - Eco Throttle OK? stevejones Generators & Solar Power 2 04-14-2019 08:08 PM
Honda EU2200i Cispook Generators & Solar Power 30 03-22-2019 04:03 AM
Honda EU2200i vs 3000i on propane nryn Generators & Solar Power 20 09-26-2018 11:12 AM
New Model Honda EU2200i RxGuy Generators & Solar Power 13 02-10-2018 05:37 AM
