05-08-2016, 07:02 AM
#61
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Originally Posted by TG Twinkie
As I recall my Yamaha 2,000 manual says to: shut off the fuel; run it till out of fuel in carb; drain carb bowl and fuel tank. It does require removing the side panel (easy).
Yea. That's pretty much it. But one reason I bought the yamaha over the honda was the fuel shutoff. That you still have to drain the carb was something I didn't pick up on.
@living.somewhere.yonder | Instagram
05-08-2016, 07:17 AM
#62
Sneedville
, Tennessee
Originally Posted by AWCHIEF
Prez, I understand. I made the rounds of the Honda and Yamaha dealerships checking out generators. I was hoping to find one that would safely run my AC. Unfortunetly anything bigger than the 2000 models were just too much for my back. I have limited on the road storage so size was also a big issue. Got the best deal on the Yamaha thru their authorized outlet.
I rarely use mine, but when I just slide it to the tailgate. Trying to lift it from the ground up to the tailgate is just too much.
05-09-2016, 06:31 AM
#63
Biloxi
, Mississippi
No tailgate, I drive a Jeep GC. Might have to go back to a pick up if I can ever go full time.
MICHAEL
05-11-2016, 03:09 PM
#64
Biloxi
, Mississippi
Tried my trailer AC with the new Yamaha 2000 propane converted generator today. It quickly goes into overload mode and shuts down output. So much for hoping it might run my 13.5 unit. No problem running the micro wave, Television and plug in fans.
MICHAEL
05-11-2016, 03:21 PM
#65
2014 30' Flying Cloud
Tampa
I just had my EU2000i serviced, and it again runs like new. Planning on attaching it to the v frame and putting a cover on it.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
05-11-2016, 03:42 PM
#66
2004 30' Classic Slideout
Fenton
, Missouri
I just ordered a Yamaha EF2000iSv2 the other day from http://www.uscarburetion.com The big reason I ordered this instead of a Honda was the fact that the tri-fuel system that US Carburetor builds will not void the Yamaha warranty. I don't believe that Honda will still warrant their generator if you install the tri-fuel assembly.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
05-11-2016, 06:02 PM
#67
2013 27' FB International
El Dorado Hills
There's someone on this forum who claims it works with a 2000 unit. I think he said the AS power switch has to be in the store (not use) position in order to disconnect the batteries. All lights off and everything else off.
05-11-2016, 06:03 PM
#68
2012 27' Flying Cloud
W
, New England
I can run the AC with a pair of 2000 generators. Never tried with a single.
05-11-2016, 06:16 PM
#69
2014 25' FB Flying Cloud
2005 30' Classic
Keswick
, Virginia
We had a Honda 2000 for maybe 9 years for our duck hunting cabin, running it all evening for lights and cooking. It ran a vacuum cleaner when cleaning the cabin. Any time we came in to warm up, we would start it up. Dead of winter, freezing cold, it always cranked on the first try or sometimes the second. Finally one of the young guys said it was getting old so he bought it from the club and bought us a new Yamaha. It's good, similar, but I'd take that old Honda back. Maybe it was just one of those good machines you get every now and then, but I'm a Honda fan. Then there's the 30 year old Johnson outboard motor, but I digress.
05-11-2016, 06:31 PM
#70
Biloxi
, Mississippi
I recently posted a video I found on Facebook. It perported how to run the AC using a single 2000. Basically like you said, turn off everything else in the trailer including the converter/battery charging system, fridge, lights. I was too lazy today to try all that. Will watch the video again and try tomorrow maybe.
MICHAEL
05-11-2016, 06:38 PM
#71
Salem
, Oregon
Hi, a friend of mine said he runs his 13,500 air conditioner with his Honda 2000; But he changed his start capacitor.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-11-2016, 06:46 PM
#72
Biloxi
, Mississippi
MICHAEL
05-11-2016, 06:48 PM
#73
Biloxi
, Mississippi
Any details on how to do this?
MICHAEL
05-11-2016, 06:51 PM
#74
Biloxi
, Mississippi
This
http://youtu.be/oHgXGlYNYkQ
MICHAEL
05-11-2016, 07:01 PM
#75
Biloxi
, Mississippi
This looks like what was used in the above video
http://www.amazon.com/dp/B00YK1BT3W?psc=1
MICHAEL
05-11-2016, 07:05 PM
#76
2005 31' Classic
Pleasant Plains
Other. I recently bought a Champion 2000w unit. So far, I'm satisfied with it.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
05-11-2016, 07:20 PM
#77
Lin
, Ne
Originally Posted by J. Morgan
Ny Yamaha 2400 will run for two or three minutes or so after cutting the fuel, leaving the float bowl MOSTLY empty.
Superat stultitia.
I can open the side cover and drain the carb on my Honda's in under a minute.
05-12-2016, 10:06 PM
#78
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Hey, I took the side cover off of my Yamaha today, if has a float bowl drain too!
Superat stultitia.
05-23-2016, 04:39 PM
#79
2018 19' Flying Cloud
Eugene
, Oregon
This is definitely a newbie question - but would there be any advantage / difference / or reason in charging my two 12v batteries ( in parallel - when boondocking) with a Honda eu1000 via a BatteryMINDER vs plugging the power cord (with the 110 adapter plug) directly into the trailer? Would one way charge faster or keep from over charging? I'm talking just re-charging, not running anything.
05-23-2016, 06:08 PM
#80
Fenton
, Missouri
Jack Canavera
STL Mo.
AIR #56 S/OS#15
