Old 05-11-2016, 06:38 PM   #71
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by AWCHIEF View Post
I recently posted a video I found on Facebook. It perported how to run the AC using a single 2000. Basically like you said, turn off everything else in the trailer including the converter/battery charging system, fridge, lights. I was too lazy today to try all that. Will watch the video again and try tomorrow maybe.
Hi, a friend of mine said he runs his 13,500 air conditioner with his Honda 2000; But he changed his start capacitor.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-11-2016, 06:46 PM   #72
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Found it. It is about using a 3000 watt generator.
https://m.youtube.com/watch?feature=...&v=Y6SeSCTAY5o
MICHAEL
Old 05-11-2016, 06:48 PM   #73
AWCHIEF's Avatar
Images: 33
Any details on how to do this?
MICHAEL
Old 05-11-2016, 06:51 PM   #74
AWCHIEF's Avatar
Images: 33
This
http://youtu.be/oHgXGlYNYkQ
MICHAEL
Old 05-11-2016, 07:01 PM   #75
AWCHIEF's Avatar
Images: 33
This looks like what was used in the above video
http://www.amazon.com/dp/B00YK1BT3W?psc=1
MICHAEL
Old 05-11-2016, 07:05 PM   #76
2005 31' Classic
Pleasant Plains , Illinois
Other. I recently bought a Champion 2000w unit. So far, I'm satisfied with it.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 05-11-2016, 07:20 PM   #77
r carl's Avatar
Lin , Ne
Originally Posted by J. Morgan View Post
Ny Yamaha 2400 will run for two or three minutes or so after cutting the fuel, leaving the float bowl MOSTLY empty.
Superat stultitia.
I can open the side cover and drain the carb on my Honda's in under a minute.
Old 05-12-2016, 10:06 PM   #78
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Hey, I took the side cover off of my Yamaha today, if has a float bowl drain too!
Superat stultitia.
Old 05-23-2016, 04:39 PM   #79
2018 19' Flying Cloud
Eugene , Oregon
This is definitely a newbie question - but would there be any advantage / difference / or reason in charging my two 12v batteries ( in parallel - when boondocking) with a Honda eu1000 via a BatteryMINDER vs plugging the power cord (with the 110 adapter plug) directly into the trailer? Would one way charge faster or keep from over charging? I'm talking just re-charging, not running anything.
tjwoods1 is offline   Reply With Quote
Old 05-23-2016, 06:08 PM   #80
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Broke in my Yamaha today. http://www.airforums.com/forums/f448...ml#post1795950
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-23-2016, 06:53 PM   #81
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Plugging the trailer in will be much faster, and from what I read it takes days do "cook" batteries with the stock converter.
Superat stultitia.
Old 06-04-2016, 07:36 PM   #82
2011 28' Flying Cloud
Orillia , Ontario
Champions
I have two 2000 watt champions with parallel kits.
George
Rust is offline   Reply With Quote
Old 06-12-2016, 02:06 PM   #83
AWCHIEF's Avatar
Images: 33
Using my propane converted Click image for larger version
Name:	ImageUploadedByAirstream Forums1465761967.585156.jpg
ID:	264355Click image for larger version
Name:	ImageUploadedByAirstream Forums1465761992.448684.jpg
ID:	264356Yamaha 2000 for the first time. Dry camping on the Blue Ridge Parkway. I am in nearly 100% shade so unable to use the Renogy solar suitcase.
MICHAEL
Old 06-12-2016, 02:39 PM   #84
2015 30' Classic
Pleasanton , California
The 2015 sport manual says it includes a 3-stage converter/battery charger. Since this supply can deliver more current than your BatteryMINDER, you'll charge your system much faster by simply connecting your generator to the trailer's shore power inlet and let the trailer's converter charger your batteries. Make sure your battery disconnect switch is in the On position to ensure that your converter will charge your batteries.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Do you own a 21' Sovereign? hamboblett 1992 - 1996 Sovereign 95 04-20-2018 08:01 AM
Which would you rather own and why? Glamper1 Buyer Guidelines 23 07-20-2015 08:21 AM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Any of you Minuet owners done your own brakes? Van All Argosy Trailers 7 06-02-2010 06:54 AM
What length Classic Motorhome do you own? ALANSD Classic Motorhomes 58 02-14-2009 04:12 PM
