Old 05-07-2016, 07:18 AM   #57
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Completed the US Carburetion propane conversion of my brand new Yamaha EF2000iSv2 yesterday. Very straight forward process. Took a few pulls to get the fuel block adjusted and then she started right up. Runs relatively quite and no gasoline exhaust smell. The plan is to eventually get another so that I can run the AC when necessary. The hardest part of the process was drilling holes in the brand new generator and considering placement of the regulator. That took some quality time in the thinking chair?
MICHAEL
Old 05-07-2016, 07:32 AM   #58
Tincampers's Avatar
Sneedville , Tennessee
We have the Yamaha 2400 ischemic with propane conversion. It will run the AC. I've never run the AC on the generator since we've had it. If I had to do it over, I'd go with something much smaller. It is a brute to move around. It's for sale if anyone is interested.
Tincampers is offline   Reply With Quote
Old 05-07-2016, 08:42 AM   #59
AWCHIEF's Avatar
Images: 33
Prez, I understand. I made the rounds of the Honda and Yamaha dealerships checking out generators. I was hoping to find one that would safely run my AC. Unfortunetly anything bigger than the 2000 models were just too much for my back. I have limited on the road storage so size was also a big issue. Got the best deal on the Yamaha thru their authorized outlet.
MICHAEL
Old 05-07-2016, 09:38 AM   #60
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Which do you own?
As I recall my Yamaha 2,000 manual says to: shut off the fuel; run it till out of fuel in carb; drain carb bowl and fuel tank. It does require removing the side panel (easy).
TG Twinkie is online now   Reply With Quote
Old 05-08-2016, 07:02 AM   #61
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Yea. That's pretty much it. But one reason I bought the yamaha over the honda was the fuel shutoff. That you still have to drain the carb was something I didn't pick up on.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-08-2016, 07:17 AM   #62
Tincampers's Avatar
I rarely use mine, but when I just slide it to the tailgate. Trying to lift it from the ground up to the tailgate is just too much.
Old 05-09-2016, 06:31 AM   #63
AWCHIEF's Avatar
Images: 33
No tailgate, I drive a Jeep GC. Might have to go back to a pick up if I can ever go full time.
MICHAEL
Old 05-11-2016, 03:09 PM   #64
AWCHIEF's Avatar
Images: 33
Tried my trailer AC with the new Yamaha 2000 propane converted generator today. It quickly goes into overload mode and shuts down output. So much for hoping it might run my 13.5 unit. No problem running the micro wave, Television and plug in fans.
MICHAEL
Old 05-11-2016, 03:21 PM   #65
FCStreamer's Avatar
2014 30' Flying Cloud
I just had my EU2000i serviced, and it again runs like new. Planning on attaching it to the v frame and putting a cover on it.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-11-2016, 03:42 PM   #66
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I just ordered a Yamaha EF2000iSv2 the other day from http://www.uscarburetion.com The big reason I ordered this instead of a Honda was the fact that the tri-fuel system that US Carburetor builds will not void the Yamaha warranty. I don't believe that Honda will still warrant their generator if you install the tri-fuel assembly.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-11-2016, 06:02 PM   #67
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
There's someone on this forum who claims it works with a 2000 unit. I think he said the AS power switch has to be in the store (not use) position in order to disconnect the batteries. All lights off and everything else off.
kscherzi is offline   Reply With Quote
Old 05-11-2016, 06:03 PM   #68
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I can run the AC with a pair of 2000 generators. Never tried with a single.
Old 05-11-2016, 06:16 PM   #69
gregwall's Avatar
2014 25' FB Flying Cloud
2005 30' Classic
Keswick , Virginia
We had a Honda 2000 for maybe 9 years for our duck hunting cabin, running it all evening for lights and cooking. It ran a vacuum cleaner when cleaning the cabin. Any time we came in to warm up, we would start it up. Dead of winter, freezing cold, it always cranked on the first try or sometimes the second. Finally one of the young guys said it was getting old so he bought it from the club and bought us a new Yamaha. It's good, similar, but I'd take that old Honda back. Maybe it was just one of those good machines you get every now and then, but I'm a Honda fan. Then there's the 30 year old Johnson outboard motor, but I digress.
gregwall is offline   Reply With Quote
Old 05-11-2016, 06:31 PM   #70
AWCHIEF's Avatar
Images: 33
I recently posted a video I found on Facebook. It perported how to run the AC using a single 2000. Basically like you said, turn off everything else in the trailer including the converter/battery charging system, fridge, lights. I was too lazy today to try all that. Will watch the video again and try tomorrow maybe.
MICHAEL
Do you own a 21' Sovereign? hamboblett 1992 - 1996 Sovereign 95 04-20-2018 08:01 AM
Which would you rather own and why? Glamper1 Buyer Guidelines 23 07-20-2015 08:21 AM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Any of you Minuet owners done your own brakes? Van All Argosy Trailers 7 06-02-2010 06:54 AM
What length Classic Motorhome do you own? ALANSD Classic Motorhomes 58 02-14-2009 04:12 PM
