That would be a great location in day to day use & it would be an easy area to work in but I wonder whether it's a problem being that far from the battery bank(at the front).
On my 2008 23 ft Int. there is a light blue wire clearly marked "Solar" behind the Micropulse control panel (Fresh, grey, and black water status indicator). I just pried face of the panel off, and there it was. Airstream installs the solar control panel just above the Micropulse panel. I spoke with Jim Parret at Airstream and he said this is part of the "Solar pre-wire package". I'm so glad they did this. It makes it so easy to install the solar panel systems when that time comes.
The controller prewire on a 25'FB - Queen is under the bed on the C.S. closest to the front wall. The Display prewire is behind the tank monitoring system panel in the galley. The PV panel wires are behind the refrigerator accessed through the lower louvered vent.
Patrick Botticelli
Colonial Airstream
1121 Route 88/ Ocean Ave.
Lakewood, NJ 08701
1-800-265-9019 or 732-367-4499 www.colonialairstream.com
Regards
Paul
Paul
FYI
I am pretty sure on a 23D International Signature the controller prewire in under the front dinette on the R.S of the trailer. The Display prewire is behind the Tank Monitor Panel.
Patrick Botticelli
Colonial Airstream
Lakewood, NJ 08701
Patrick you are right about the display prewire. It's great to have someone with your expertise here.
Evan
I took a picture of the display prewire for you. Remember if you pry off the face of the Micropulse display, pry from the top of the display only, not the bottom. There are two metal holding "catches" that wont budge..
