Old 08-01-2010, 07:59 PM   #1
1995 30' Limited
Tygh Valley , Oregon
Where do I connect the solar charge controller on an '87 Soverign?
I own an 87 Sovereign and just purchased a 20 watt GoPower solar kit in order to keep my batteries charged while my trailer is in storage. The kit comes with a Morningstar charge controller that needs to be connected to the two 12 volt batteries that are wired in parallel in the front of the rig.
My question is, where exactly should I tie in the charge controller to the existing 12 volt wiring. I've attached a PDF file of the 12 volt wiring taken from the original owner's manual.
I'd really appreciate it if someone could indicate exactly where on this diagram I should connect the 12 volt leads that come out of the charger controller.
Thanks.Sovereign 12 volt wiring 1.pdf
willbrackman is offline   Reply With Quote
Old 08-01-2010, 08:05 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
We connect right to the batteries when installing AM Solar charging systems by running a dedicated charge line directly from the controller. Usually, 8 or 6 AWG, fused or with a 40 DC amp circuit breaker. With only a 20 amp panel, you don't need a heavy gauge like we use. Probably, 12 AWG will work well. It depends on the maximum amperage that the controller will output to the batteries.
A 20 watt panel will only give you a 'trickle' charge of about 1.6 amps peak or so. Fine to maintain batteries that are already charged, but will take a very long time to charge batteries that are depleted.
Old 08-01-2010, 08:11 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You can connect the positive from the controller to the "12v battery kill switch" terminal and ground the negative from the controller to the frame or other suitable ground.
Another way is to connect the positive from the controller to a battery positive, and the negative to a battery negative. The positive battery terminals are connected together at the kill switch, and both battery negatives are connected to ground, thus, your batteries are connected in parallel.
Do whatever is easiest. Any positive will go to both batteries, and any good ground will do the same.
All of the above is predicated on your unit being wired as the diagram shows.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Whats the best Solar Charge Controller? Keyair Generators & Solar Power 17 05-09-2011 05:04 PM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Morningstar - Prostar charge controller, outside installation wacnstac Generators & Solar Power 5 06-07-2007 02:53 PM
Electrial surge charge controller WayWard Wind 1997 - 2004 Bambi 0 05-05-2003 08:28 PM
