Old 01-29-2016, 02:36 AM   #29
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
http://www.airforums.com/forums/f37/...cs-112618.html
Larry
lsbrodsky is offline   Reply With Quote
Old 01-29-2016, 01:49 PM   #30
2015 28' International
Ofallon , Missouri
Originally Posted by lsbrodsky View Post
MOST EXCELLENT THANKS! I know I want (need?) one but I have been studying the "how" before leaping ...
mpsgolf is offline   Reply With Quote
Old 04-26-2016, 06:39 PM   #31
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
For those with 25fbs and have mounted a Trimetric, IPN Pro Remote etc do you have to remove the fridge too run the cable down to the floor?
Kelvin
Old 04-27-2016, 08:15 AM   #32
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We had to remove the Classic fridge to get the solar panel power feed cable down through the refrigerator chimney along with the Verizon modem antenna and WiFi Ranger feeds. We also used some insulation and tape to block the hole in the wall in back of the thermostat in the refrigerator space which makes it read the room temperature rather than the air temp in the refrigerator space.
Also, this allows the wood support panel we made of Hickory for the thermostat, Magnum ARC-50 and TriStar displays to fastened to the wall from the refrigerator side with no screw heads showing in the front. See my avatar to the left that shows the Classic mission control area also with the SeeLevel control head above the WW II ship's clock.
Old 05-02-2016, 09:45 PM   #33
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
No, we didn't remove it. Have done so several times but last three times I ran cables without moving fridge. Three different methods, in order: coat hanger as fish tape; ball chain (from big vertical blinds) for hanging down from roof to pull spot; and finally a 25' Klein fish tape. Why in the world I didn't go to the fish tape the first time, I can regretfully say, was stupidity.
Anyway, pulled the tstat off the wall, made a 3/4" hole above it at location for new Trimetric meter, soaped the jacket on the cat-5 cable and pulled it from fridge outside access using the coat hanger wire. Snug but zero problems. Fish tape would only have been twice as easy and quicker.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 05:31 PM
Help! How did you install your Trimetric? lsbrodsky Electrical - Systems, Generators, Batteries & Solar 20 08-14-2014 04:55 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 07:59 PM
Trimetric 2020 davidz71 Electrical - Systems, Generators, Batteries & Solar 3 01-30-2007 09:29 PM
Trimetric 2020 meter nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 3 02-26-2005 08:49 AM
