Old 04-05-2011, 03:59 PM   #15
2005 28' Safari
I'd recommend BlueSky Energy
Blue Sky Energy Inc. | Our Products
Sounds like the 2512i would be a good match. I've used them since their first MPPT controller came out. There is a remote monitor available as well.
PaulAir is offline   Reply With Quote
Old 05-09-2011, 04:00 PM   #16
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I would recommend the Morningstar Tristar TS-MPPT-45.....I have used the Blue Sky unit and wasn't happy with the performance or quality.....
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-09-2011, 04:51 PM   #17
2005 28' Safari
I used the BlueSky SB50 in a home installation and have had no problems and don't know about their other products. For the safari, my plans are for high voltage input, which Blue Sky doesn't have a matching product.
I'm looking at the Outback FlexMax or the Morningstar and leaning toward the TS-MPPT-45. I look forward to seeing it in action at the rally.
Old 05-09-2011, 05:04 PM   #18
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I had originally installed a Blue Sky Solar Boost 2000E based on a friends install....it turned out to be too small for my setup and that's when I moved to the Morningstar TS-MPPT-45.
Also, the Blue Sky only is a 3~stage charger vs the Morningstar which is a 4~stage charger.
The physical size and weight between the two controllers is no comparison.....
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Morningstar - Prostar charge controller, outside installation wacnstac Generators & Solar Power 5 06-07-2007 02:53 PM
Electrial surge charge controller WayWard Wind 1997 - 2004 Bambi 0 05-05-2003 08:28 PM
