Old 10-14-2015, 11:04 AM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by AnnArborBob View Post
If the OP has seen 8 & 9 volts on his voltmeter then his current batteries are toast and not much can be done to save them.
It's not at all unusual for the first set of batteries on a new Airtream (or any RV) to be in very bad shape due to understandably poor treatment by the dealer while on the lot (who has time and manpower to check and make sure the batteries are fully charged all the time or not overcharged by continuous connection to shore power?)
See if you can get the batteries replaced under warranty and then get a 3 stage charger as previously suggested to take better care of your new batteries.
yup.. new Battery AND Converter time... contact 'Lewster' on this forum for Lifeline batteries..
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-25-2015, 01:19 PM   #16
1996 25' Excella
Tillsonburg , Ontario
I'm sure the batteries are toast.
If you discharge a deep cycle battery down to less than 10V then you will take 10% off the capacity of the battery. Every time you do this it takes another 10% off the capacity. Do the same thing with a Car starter battery and the number is closer to 25%.
Look up the battery charge tables on the Internet and keep one handy....such as
Battery voltage and state of charge - Energy Matters
JCW
JCWDCW is offline   Reply With Quote
12v
What cooling should I expect from a new fridge? DHart Refrigerators 30 08-13-2015 03:02 AM
What should I expect to pay for new brakes and tires Mary Burris Wheels, Hubs & Bearings 2 05-22-2012 06:59 PM
What can I expect to pay for a complete Battery system ? mountainsun Batteries, Univolts, Converters & Inverters 12 03-31-2012 10:08 PM
Should I expect some rattling from my Interstate? rv40 Sprinter and B-van Forum 12 03-18-2010 08:35 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
