Old 01-18-2010, 10:00 AM   #1
mistermike's Avatar
1968 17' Caravel
Marblehead , Hasslechusetts
What Generator Do You Recommend?
I want to purchase a small generator. I want something that is quiet and trouble free. What would you recommend?
"Mister Mike", Chief Engineer, Amateur Radio Station W1RC
Founder and Benevolent Dictator, New England Amateur Radio Festival, (aka NEAR-Fest),
At the Beautiful Deerfield NH Fairgrounds (Next one May 4th and 5th 2018)
"Best #@! Hamfest on the Planet!"
www.near-fest.com
mistermike is offline   Reply With Quote
Old 01-18-2010, 10:11 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I am very satisfied with my Honda. Your usage will determine which model to get. I use mine to top off the battery and I use a EU1000i.
Richard
Old 01-18-2010, 10:12 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
For a quiet generator you need an inverter type. They are considerably more expensive but also significantly quieter. The most common one is a Honda EU2000. Yamaha and other manufacturers make comparable and larger versions. Honda also makes the smaller version mentioned above. I don't know if others also have an inverter in the 1000 watt range. What do you anticipate you will use it for?
Old 01-18-2010, 10:38 AM   #4
cameront120's Avatar
1972 25' Tradewind
I'm very happy with my Honda eu2000. It's a great little machine. Since I don't have air conditioning, it runs everything in my trailer without any problem.
North Vancouver, BC
Old 01-18-2010, 10:40 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Hard to believe the Chief Engineer of W1RC doesn't have a Genny. I have one but its to noisy to take campin.
I would suggest just from my observations(dealing with small engines) that the Honda is probabley the most trouble free. Depending on how you intend to use and transport it. I think Honda EU2000 at 47 lbs will be the easiest to handle and a pair will give you 4000 watts to run your AC or your Ham Rig.Although U need to understand that what ever Genny you decided on will have to be serviced (oil changed and AirFilter) every 25 to 30 hrs. runtime. IT will only be as trouble free as the maintainence you give it. With the current econimic conditions,I'd look around for some NIB/OS. I think some dealers would love to get rid of last yrs stuff they still have in the back room. GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 01-18-2010, 10:43 AM   #6
2008 16' Safari
Destrehan , Louisiana
There is no such thing as a trouble free generator. They all require care. Frequent oil changes, oil filter, air filter etc. They all use a lot of fuel for the watts produced. 30% effecencey is about the best you will get.
We are using a Generac Guardian RV quiet-pack unit that puts out 120 VAC @ 30 amps and runs on propane. We can run everything in the trailer with this unit. That includes the AC and the microwave. (just not both at the same time!)
The good side is very little noise and a clean running unit. It uses propane so I can run it from the trailers LP bottles if I have to.
The bad side is the cost and size on the generator. I have it mounted on a small trailer ( it weighs 170 lb) Generac list these at $2800.00 and typical discounts are about $2000.00.
We live near New Orleans so this generator is not just for the camper. This is our power back-up during storm season. That's the only reason I could justify the cost.
The little Honda units are also very good, but they ain't cheap either. You get what you pay for. We had a Briggs&Straton powered unit before this. It was loud, un-reliable, a gas guzzler and failed when we needed it the most.
dlb435 is offline   Reply With Quote
Old 01-18-2010, 11:39 AM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I would go with Yamaha or Honda, and the smallest that will meet your needs. If you are mostly recharging batteries, look at the 1000 watt models. I have the Yamaha 2400is with the propane conversion. Love it, but most times would really be better off with a smaller unit.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 01-18-2010, 11:43 AM   #8
I use the Honda 3000 Handi model, but I need that much power to run the A/C. If I lived in another part of the country and didn't need to use A/C so often, I would have gone with the 2000 or even 1000 model.
Old 01-18-2010, 11:44 AM   #9
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Any Honda, Yamaha, Subaru inverter style generator. Pick the size that suits your needs. I had a Robin-Subaru that was great, but was not large enough to power my AC or Microwave. Last year I moved up in size to a Yamaha ES2400is which is great. You may not need on that large, all of these brands offer units starting at around 1000w.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 01-18-2010, 11:51 AM   #10
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Generators
I use the Honda 3000 because it will run our air and everything else in the trailer. I can run it in the eco mode (lower rpms) with the air on and it is really quite. It is a bit heavy so I have it locked in the back of my pick-up for the camping season. When I run the gen. I just fold back a bit of the bed cover. When I purchased it I checked out the idea of running 2 Honda 2000's as each is much lighter to handle. The fact is the 2 of them running at the same time made more noise than the 3000. I'm very happy with the Honda 3000.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-18-2010, 12:34 PM   #11
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
I have 2 generators, a Yamaha 2400 converted to propane which will run my AC, but I don't use very often since I like to go places where you don't need AC. Since it's set up for propane I don't have to worry about fuel going bad when it sets a long time.
I also use a Yamaha 1000 for those time when my solar panels need a little help charging the batteries. It's a great little generator, 29 lb, it's supposed to be quieter then the compareble Honda, but I don't think the difference would be noticible to many.
Sometimes I think I also need an extra noisy Chinese cheapo for those times I have obnoxious neighbors.
snake is offline   Reply With Quote
Old 01-18-2010, 01:09 PM   #12
airstream66's Avatar
1966 30' Sovereign
Bethany , Illinois
Images: 22
I have a Chinese Cheapo' and it does drown out the neighbors and the critters very well. Most of the time, where I use mine there aren't any neighbors. I would have gotten a Honda but can't justify that for the one trip I take a year. Mine is a 3000w and has plenty of juice to start the A/C. A honda would work very nicely at your HAM 'field day' as well. But, my dad is a HAM and they use all kinds at their field day and none of them are Honda's.
Cory, Angie, and 'Lucy'
1966 Sovereign International
2003 Black Chevy Silverado w/q-steer
airstream66 is offline   Reply With Quote
Old 01-18-2010, 01:21 PM   #13
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
Great info from tkasten about the two Honda 2000's... I was considering those but if they are louder than the 3000, I think my mind is made up!! Thanks...
Utahgoldrup is offline   Reply With Quote
Old 01-18-2010, 01:58 PM   #14
Airstream01's Avatar
2008 25' Safari FB SE
Land of fruits and nuts , California
I'm going to be purchasing two Yamaha EF200iS generators and the parallel cables in the very near future. They weigh only 44lbs each and I can fit both of them in my truck box when not in use. Paralleled they'll run my A/C and a few other things.
I also have a big 3500W craftsman generator that I've quietened up a bit, but it is so heavy and big it is hard to pack, so It has become a backup power generator for my house.
Airstream01 is offline   Reply With Quote
Patio Rugs - what do you have? like? not recommend? Pudentane Off Topic Forum 32 02-28-2010 08:13 PM
WHO would you recommend that might have the part..... lonster All Argosy Trailers 1 07-06-2009 08:26 PM
recommend a catalog or two pinkflamingoes Commercial Listings 18 07-13-2004 04:31 PM
Austin,TX-which route would you recommend John On The Road... 18 01-13-2003 01:02 PM
Delivery companies...any you can recommend virginiak Our Community 3 06-22-2002 09:47 AM
