Old 06-09-2011, 06:58 AM   #1
1978 28' Ambassador
mcconnelsville , Ohio
What Gen runs A/C for 1978 ambassador?
Anyone know what size generator can operate the AC unit on our camper? I don't know much about the unit other than it is origanal equipment.
mohrjr is offline   Reply With Quote
Old 06-09-2011, 07:02 AM   #2
Lothlorian's Avatar
Loganville , Georgia
I have a 27' and I use a 15,000 BTU Coleman.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-09-2011, 07:07 AM   #3
1978 28' Ambassador
thanks how many watts?
Old 06-09-2011, 07:11 AM   #4
Lothlorian's Avatar
I really do not know the watts. My air conditioner is an old one and I know it pulls the amps. I use a 3500 watt generator with it. that is about all I can tell you.
Brian
Brian & Adrienne
Old 06-09-2011, 08:55 AM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Your vintage A/C unit probably pulls about 3000 Watts. They're hungry units.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-09-2011, 09:18 AM   #6
richinny's Avatar
2011 34' Classic
there are a lot of threads on this topic. it's not just the watts but the surge from starting. for air conditioner use you're looking in the 2800w+ range.
Google Custom Search
Ricky
Old 06-09-2011, 10:44 AM   #7
You will not be operating the AC "only".
When you plug the trailer into a source of AC power, the Univolt automatically grabs some power.
Next, no generator should be loaded to more than 80 percent.
Therefore, if you use a 3000 watt generator, your limit is 2400 watts. The AC, depending on the ambient temperature can draw almost 1800 watts. That then leaves enough for the univolt to properly function as well.
Also, keep in mind that the instant starting current draw of your AC, exceeds the 1800 watts. If the generator is under powered, the compressor in the AC, will not start.
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 05:59 PM
Water Stains on Ambassador? MATTY J Cleaning, Stripping & Polishing 6 05-01-2011 08:28 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
