Old 02-27-2015, 11:12 PM   #1
Starstream's Avatar
Spring , Texas
Wanting to know if??
From reading the various threads, it is safe to say most people prefer either a Honda or Yamaha inverter type generator.
At the current time and for the time in the near to mid future, Not able to afford one of them.
Hence these, they are in my price range, have a decibel of 53 at 23ft. Weighs in a just under 50lbs. Run time of 9 and a half hours at 25%load. Two can be combined to reach the magic 4,000 watts needed to run most everything in the AS. The other nice factor of this one is they are stackable.
2000W Inverter Generator (CARB) - Champion Power Equipment
I would like to know if anyone has one or two, used them and what the good-bad-ugly of them are?
Thank you all in advance for any and all information
Starstream is offline   Reply With Quote
Old 02-28-2015, 03:29 AM   #2
Baltimore , Maryland
generally, you get what you pay for. I have a generator I bought, thinking I could not afford the good one. It now acts as a table to set my Yamaha 2000 on in the storage shed.
Old 02-28-2015, 04:42 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have seen the Champions and have a camping buddy that has a pair that has been going strong for 3 years of camping use. He uses them 5-6 times a year camping, then uses them one at a time around home for powering up stuff away from the house when doing maintenance.
I have done a lot of research. Biggest issue with the Champion IMHO is that they don't have a fuel pump, therefore putting an expansion fuel tank on them to increase the run time is not easy. They also have relatively small fuel tanks. None of the off the shelf expansion tanks will work. I camped next to my buddy a year ago on an extremely hot weekend. He was having to fill them up every 5-6 hours. I had a Yamaha EF3000 and could go closer to 12 hours between fill ups. I think it is interesting that Champion lists the fuel consumption rate in hours per 1/4 load while Yamaha and Honda list theirs in hours per 1/2 load.
Aaron
WBCCI #XXXX AIR #2495
Old 02-28-2015, 05:50 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
When I worked had a distributor which carried a number of different portable generators. When I was looking for one for our AS he told me the Honda's have fewer issues and are "in his shop" less often than any other brand. Further the Yamaha's were a very very close second. All others, made him money at the sale and for a long time after until people decided to switch to either Honda or Yamaha. We like our two Honda's, don't use them much at all, but they are five years old and start right up when asked, I do a lot of PM on them at the end of each season.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-28-2015, 01:30 PM   #5
SKP46015's Avatar
Bite the cost bullet and get one or two Honda EU-2000s with a parallel wiring kit. Like the others said... you get what you pay for. I've have my two for over ten years and if you maintain them and change the oil every year... they seem able to soldier on forever...
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 02-28-2015, 02:31 PM   #6
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Is the purpose of using two Honda EU2000s rather than a larger Honda EU3000 the weight? Or so one is likely to be working in case one is down?
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 02-28-2015, 02:53 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
4000 or 6000 when paired...
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 02-28-2015, 03:04 PM   #8
white laker's Avatar
2002 31' Classic
lanark , Ontario
Hey Mainstreamer
I have a 3000i and have for a few seasons. I use it at the cottage for backup as well as for camping when needed. Te best advantage for me was added versatility and only one machine to maintain. Some folks want the smaller 2000 as they burn less fuel but they only run as fast as required. The 3000i is heavier but you can always find a helping hand. the electric start is a nuce touch too. My opinion if you are going to a 2000i and money is an issue, buy one and when the cash reserves are good to go again, pick up the mate to it. I would stay away from the 'throw aways' at all cost. Honda Yamaha are more expensive now but cheaper in the long run for sure.
white laker is offline   Reply With Quote
Old 02-28-2015, 03:31 PM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I've had the two Honda 2000's for seven years now. I've never taken real good care of the, but they always work when asked.
I opted for the two 2000's for the versatility. If I,m not using the air conditioner, one will do the trailer. I also use just one for the truck camper, even with the a/c. I can easily lift them in and out of the truck.
Brian
SuEllyn & Brian McCabe
Old 02-28-2015, 05:26 PM   #10
2018 33' Classic
Newport , Pennsylvania
What do you need if you want to run 2 AC units and have 50 Amp
I looked at a new honda fuel injected 6500 watt with electric start $3995
Anybody have ant advice pro or con.
EarlM is offline   Reply With Quote
Old 03-11-2015, 07:44 AM   #11
2014 27' FB International
Longview , Texas
Earl,
Not being a wise ass but i asked muchly the same question of Airstream itself. Have a 28FB International onxy (2014) Two A/Cs and other standard stuff. I aksed what I would need if i wanted to run everything at once in the trailer and they told me 12K. so now I am more confused than ever. I have a 22K Generac at the house which literally powers everything in a 3,000 ft house in the dead heat of a texas summer
Wayne Clamp is offline   Reply With Quote
Old 03-11-2015, 02:19 PM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Running a generator at 25% load is a great way to ruin a generator over the long term. They operate most efficiently when loaded between 50% and 75% of their rated load, or between 1kW and 1.5kW load in your case.
2kW is maximum capacity for that generator, when loaded to 100% and running at maximum RPMs— that's actually a simplification because I want to avoid getting bogged down in torque and power curves— but for talking purposes, close enough. And I guarantee that it's a lot louder than 53dB when running under a load, and the fuel in the tank worn't last half as long as advertised then, either. Don't me misled by manufacturer's claims that don't coincide with your intended usage.
Originally Posted by Wayne Clamp View Post
I asked what I would need if i wanted to run everything at once in the trailer and they told me 12K. so now I am more confused than ever. I have a 22K Generac at the house which literally powers everything in a 3,000 ft house in the dead heat of a texas summer
If you want to run everything at once in your trailer, meaning all of the lights, the water heater in electric mode, the air conditioner(s), the microwave (if you have one), etc. then 12kW is not far off the mark. But in real life you won't have everything in your trailer running at exactly the same time and you won't need that much capacity. 8kW or 9kW will be plenty, and if you're frugal about your thermostat settings and use your dual electric/propane appliances in propane mode, 7.5kW would probably be adequate. But do NOT take my word for it; I haven't done an energy analysis on your trailer so that's only a wild-assed guess.
Your 22kW Generac probavbly doesn't really run every electricity-using appliance and fixture in your stick-and-brick home at once because you don't ever use them all at once; but it does power all the ones you use at the same time. That's not exactly the same thing. That's why you should do an energy analysis before buying a generator.
Look at the wattage of all of your trailer's appliances and fixtures, and then only add up the ones you expect to have running at the same time. For example, a microwave oven doesn't run for very long at one time, so it's fine for an air conditioner to cut out while the microwave is running, as long as the air conditioner starts up again when the microwave is done. No need to run both at once or have a generator that can power both at once.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-12-2015, 08:24 AM   #13
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Camping World advertised a ~4000 watt Champion the other day that ran on both gas and propane, with a propane connection right on the front panel. It also had a 30 amp RV outlet. I think it was $600-$700. We have two Honda 2000s already, but that would be a really tempting deal, if the Champions hold up well and are relatively quiet.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-13-2015, 09:11 AM   #14
Starstream's Avatar
Spring , Texas
Thanks Skater, I saw the Camping World ad. According to the Champion web site they are rated at 75+ decibel.
But that does bring up another thought. What about converting the inverter champion to run on propane?
Wanting to replace the WHOLE bathroom... larrylisa Sinks, Showers & Toilets 24 04-01-2015 10:19 AM
Wanting to know if?? Starstream Generators & Solar Power 0 02-27-2015 10:58 PM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
Wanting to Buy-trailer park 74SovereignInt. Our Community 3 05-29-2004 09:28 AM
Just wanting to say to my new friends... KY Girl Our Community 13 12-26-2002 01:22 PM
