Old 03-07-2014, 07:25 PM   #15
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by drboyd View Post
OK, I have no much the solar option is from Airstream. Here's what the components are worth, roughly, at retail.
100 Watt Panel: $200, with hardware
MPPT Controller, with remote display: $300
Wire and connections: $100 - $200 or so
Installation labor by somebody who really knows what the #$^% they are doing: $750 (that's a wild guess)
I don't know prices on AGM batteries, but you can look those up pretty easy yourself.
What does Airstream charge?
Airstream charges what you can negotiate the dealer down to. Same as with the aluminum panels, rivets, plywood sheets, frame steel, light bulbs . . .
Doug and Cheryl
Old 03-07-2014, 07:46 PM   #16
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I had solar on my SOB. I mostly boon dock at festivals. Last Summer was my first one out in the Bambi. I know about a/c, I do not have a microwave, I changed over to leds. i use propane fridge and cooking...so my biggest use would be fantastic fan all night or heat all night. My question is..
Using a 1000k how long would I have to run it to top off my batteries in the AM? My work hours have me mostly getting back very late at night. On hot nights, I find the fan enough. Thanks for help.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-07-2014, 10:05 PM   #17
1974 Argosy 20
Kooskia , Idaho
There are too many variables to answer your question. Your degree of discharge of the batteries is unknown even with the given information. The rate of charge of your batteries from your generator is also unknown, and variable with the state of charge they begin with. Temperatures also play a roll. The type of converter/charger you have will make a difference, as well as it's rated output. What do you mean by "top off" your batteries? That is what state of charge are you willing to end at?
I am not trying to be difficult here, but without a lot more information, and some monitoring of your system, there is no answer anyone can give you with any degree of accuracy.
Sometimes just running the generator for an hour or two will be fine. That is what I would try. Or if you have to leave, chain it to your trailer and fill it with gas and go. It will run out of gas and your batteries will probably be charged. Of course maybe the neighbors will object....LOL.
Old 03-07-2014, 10:30 PM   #18
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The factory list price for the 106 watt system installed on a Classic is $2,950. The 1,000 watt factory inverter is an additional $725 and powers three outlets that become dead when on shore power.. I find that total of $3,675 more than excessive for the capability.
I had a single non-factory dealer installed 150 watt panel on the 2013 25FB and it could not recharge the original lead acid batteries during the day in the bright October sun in Albuquerque with nary a tree to be seen. The 2,000 watt Honda was necessary to top off the batteries for the next nights furnace operation that would run the batteries back down to 50%.
I have ordered six 100 watt solar panels and a Magnum MS-2800 converter/inverter that will power "all" the outlets in the new trailer all the time. There will be four 6Vdc Lifeline batteries each rated for 300 amp hours so the storage will be 12Vdc and 600 amp hours capacity.
Without installation, the materials cost for our new system with freight is just twice the factory prices above for nearly six times the capability.
Just saying that there are more bang for the bucks solar systems with third party alternatives. Check out AM Solar's Educational Pages for RV Solar Systems and read up on the where and why of solar systems.
Old 03-08-2014, 06:44 AM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Switz,
Be sure that your installer is VERY WELL VERSED in the proper method of adding you Magnum MS-2812 INVERTER/charger into your AC circuit breaker box. There are many issues with this type of conversion but when properly completed, you can operate your entire trailer (less the A/C) from your inverter when you wish.
Old 03-08-2014, 07:10 AM   #20
dkottum's Avatar
Last April we spent two weeks 250 southwest of Albuquerque without hookups or generator, but with Airstream factory solar and Lifeline AGM batteries. Our batteries were fully charged by noon each day, after using lights, some tv for movies, and furnace at night. I don't recall that the batteries went down near 50%, but the factory system has been good for us.
Doug and Cheryl
Old 03-08-2014, 01:51 PM   #21
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The factory supplier:
Carmanah Technologies Corp.
Building 4, 203 Harbour Road
Victoria, BC V9A 3S2
Tel: 800-667-6527
Fax: 866-607-6527
Complete RV Solar Power Solutions for Camping, RVing and Boating
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 07-22-2014, 04:08 PM   #22
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Agm
Switz, what is the AGM battery size and AH rating of the factory solar option? Also, where are you going to put 4 6V batteries? Thanks.
rp709 is offline   Reply With Quote
Old 07-23-2014, 07:24 AM   #23
switz's Avatar
2014 31' Classic
Images: 8
The factory solar system in years prior to 2015 models has two 53 watt panels. They replace the batteries with two group 27 batteries.
We removed the stock batteries and used the box for the BrakeRite II SD disc brake hydraulic pump and electronic controller. The four Lifeline 6CT 6Vdc 300-amp hours batteries went into a new custom stainless steel battery box.
Tongue weight with ProPride hitch head attached is 1,345 pounds.
ID:	217222   Click image for larger version
Old 07-23-2014, 09:13 AM   #24
Ed Brownfield's Avatar
2015 28' Flying Cloud
Charlottesville , Virginia
One of the dealers that I talked with quoted $3,000 for solar panels I can't remember how many watts the price purchased. Another dealer quoted $1,300 for 160 Watts and $1,000 for 95 Watts. I know nothing about solar. We just bought a 28 foot Airstream and I am trying to decide whether or not to have the dealer install solar panels. Any help from someone with more knowledge than myself will be greatly appreciated!
Ed Brownfield is offline   Reply With Quote
Old 07-23-2014, 01:21 PM   #25
lewster's Avatar
Unfortunately, most dealers have no clue about the proper way to install solar. They often use what ever components that will give them the most profit, not what best suits your needs.
Look for an expert in the RV solar field with broad experience to get the best system for you.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-23-2014, 01:30 PM   #26
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Value of Airstream Solar Package?
A solar system can be very simple or quite complicated. Pricing is obviously related to what is included and involved in the install....multiple batteries, type of batteries, number and type of panels, transfer switches, inverters with different types and sizes, simple or sophisticated charge controllers and monitoring systems. Between dealers you need to compare apples to apples before you can sign off on work. As stated, go to a dealer that knows their stuff.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 07-23-2014, 01:54 PM   #27
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I don't have the solar package on my 2008 Classic 25fb and don't really plan to be a heavy duty boondocker. I've read several blogs of Airstream owners that installed their own systems ending up with a more powerful system than the factory option. Most seem to add 2 additional batteries.
Here is one:
http://www.watsonswander.com/2013/going-solar/
What I plan to do is go with a 120 to 200 watt portable solution. Park the AS in the shade and position the panels out in the sun. I had a 17' Casita before our Airstream and found a 60 watt panel handled all our needs on the single Group 24 battery. I now have two group 27 batteries in my AS. If I find I need more than that I'll get a Honda 2000 watt generator to assist. I'm switching all the lights to LED also. This system plus a Honda 2000 would be less than $2000.
KJRitchie is online now   Reply With Quote
Old 07-23-2014, 01:58 PM   #28
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . .I have the 2 panel dealer installed solar system on my '05 25 Safari. I like the 'idea' of it but will probably not do it on my FC 28. Or at least go to a better system (ala Switz) or a couple of Yamahas. My system keeps batteries charged in storage, but in use, not so much. At the Balloon Fiesta, the solar would not run minimal lighting & the furnace fan thru the night, after all day, no use charge. It also quits working every 6 months or so, requiring trip to shop. This time, I'm trying a new shop Always an interesting topic this, thanks, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
