Old 06-16-2010, 09:02 PM   #1
billiards's Avatar
rochester , Minnesota
update ...05 safari..solar wire
just posting for future ref.......to run solar panel wire down refrig. vent from roof mount solar panel, to reach factory wire connection, the vent cover must be removed (8 rivets drilled out) /at least two rivets holding screen in place must be removed...with a little luck you can run a stiff pull wire or rod down refrig. compartment to make connection. I wasted a full day trying to fish a wire down the channel from roof vent through a half inch access hole drilled from outside the vent just under the screen and without success...30 minutes at most drilling out rivets....live and learn i guess....hope this helps someone sometime.
billiards is offline   Reply With Quote
Solar pre-wire on a 2005 19' Bambi CCD JDL Generators & Solar Power 23 12-22-2010 05:50 AM
Dedicated positive wire for solar? JimmyT Generators & Solar Power 8 05-22-2010 10:16 AM
New Caltech solar research: Silicon Wire Arrays Aristolochia Generators & Solar Power 6 03-09-2010 09:02 PM
Just say No...using plumbing vent for Solar wire access->?? eheffa Generators & Solar Power 12 10-29-2009 11:03 PM
Solar Pre-wire 2008 Safari 25 FB SE - Good enough? eheffa Generators & Solar Power 3 10-23-2009 10:30 AM
