We have a Honda 2000 generator and carry it on the frame just behind the propane tanks. It fits snugly between the tank cover and the front front panel of the Airstream. Our's is a 28ft so that may not work on the 25, but you might try it. Just as information, we also have solar panels and they work great most of the time, but clouds and trees are the enemies of solar energy so the generator often comes in handy. An added benefit of solar is that we don't have to listen to the humm of the converter when plugged into AC.
That's what I was going to suggest, that they look for a way to modify the front to carry it.
I don't think carrying it on its side is going to work because oil can flood the top cylinder heads. Think that is why they tell you to store it upright.
__________________ Just adding my 2¢ worth
John G ___________________________ 1975 31ft Sovereign International ........Rear Bath Double Bed Model Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr System: Jordon 2020 Ultima Brake Controller Hook-Up: Equalizing Hitch and Sway Bar
FYI - I picked up my 2000i from the friendly folks at H**** Equipment (not sure if I can make blatant plugs on the forum) in OK for under $900. With shipping to AZ it came in around $920. Check the Honda website for dealers. I plan to get a 2nd one and the parallel kit before next summer. That and our solar panels keep us well powered in the boonies.
Ken
__________________ 4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
Ken
SilverStreaker,
Looks like you are in AZ too. I'm located in Surprise. You placed yours behind the propane tanks. One might fit there on my 2005 25' but it would have to sit on top of the battery housing. How did you secure yours in that location?
Neil Ervin, Phoenix, Arizona (Sun City Grand)
Yes, we are in Sun Lakes, AZ (Near Chandler). We strap ours down with heavy duty shock cords, and to deter theft we attach a heavy duty cable and lock when we are not in the area.
Our batteries are on either side of the frame, so they are not in the way. There is a storage area welded into and even with the top of the frame just behind the propane tanks and the generator sits on that. If I can find some short one gallon gas containers they will go in the storage compartment under the generator.
My batteries are in a box, behind the propane tanks, and the battery box top is flush with the top of the hitch frame. I wonder if it is advisable to carry a generator, loaded with fuel, on top of the battery box due to the possibility of fuel/fumes leakage down into the battery box? Perhaps placing the generator into a plastic box before strapping down onto the battery box might be a solution.
Any recommendations folks?
BTW, have you been out to Alamo Lake State Park, west of Wickenburg? Solitude to the maximum, and hookups if you like.....
You might want to check out my post on the Bambi forum with pix showing how I mounted my honda generators on either side of the propane/battery area. I tested it this weekend and it works great. Doesn't seem to cut down my turning radius and I can plug in and run the generators anytime without moving a thing except for plugging the cord in. http://www.airforums.com/forum...ad.php?t=13142
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
