Old 09-09-2018, 11:09 AM   #1
marter's Avatar
2008 19' International
Lincoln , Nebraska
Unable to reconnect to Victron 100/20
Hello,
I'm trying to reconnect to my Smartsolar 100/20 MPPT controller and my phone doesn't see it. I was connected initially when I installed it but I disconnected my battery cables for storage, and now that I'm out camping I can't reconnect.
I can connect to the BMV-712 and can see that I'm getting a charge from the controller (and yellow light is on indicating absorption mode) but bluetooth cannot find the MPPT controller. BTW I have no jumper on the controller.
Any thoughts?
Thanks in advance,
Mike
marter is offline   Reply With Quote
Old 09-09-2018, 11:23 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
First thought is that it's not up and running. Are any of the lights on the MPPT lit?
Old 09-09-2018, 11:34 AM   #3
marter's Avatar
Lincoln , Nebraska
Hi
Yep, it's up and working. Yellow light is on now, but it's been through all lights this morning. BMV-712 shows a charge from it.
When I pulled it out if storage and tried to connect, it wasn't listed in the Victron Connect device list, but was listed as paired in my bluetooth app. Tried and tried to have VC find it again but no go. So I unpaired it in bluetooth and haven't seen it since.
Could the bluetooth on it fail? Seems odd. Tried everything I can think of on the phone (Samsung Note 8) so I'm beginning to suspect the controller's bluetooth.
Any ideas?
Mike
Old 09-09-2018, 11:56 AM   #4
Half a Rivet Short
Hi
Bluetooth can indeed fail. The other thing is that Victron is pretty specific about hooking up battery first and solar second on the MPPT's. There may be some sort of reset process you mess up if solar comes on ahead of battery. If so then:
1) disconnect everything
2) let it sit for two minutes
3) hook up the battery first
4) wait for it to boot and see if you can connect
5) then hook up solar
On my "spare" MPPT that process cured a connection error to the Venus hub.
Old 09-09-2018, 12:02 PM   #5
marter's Avatar
Lincoln , Nebraska
Thanks Bob, it's worth a try. Although if that's the case, I'll have to figure out a new storage strategy for avoiding parasitic drains.
Mike
Old 09-09-2018, 12:15 PM   #6
Half a Rivet Short
Mike
Hi
Turns out that the MPPT really does not pull a lot of parasitic current. I just leave mine on the battery side of the disconnect.
Old 09-09-2018, 12:24 PM   #7
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I tried to see my Victron solar charger on my iPhone 7 yesterday, same symptoms, was there on the device list, vanished when I clicked on it, and still there on the bluetooth list. I suspect it was an update that killed the app.
I tried an older iPad, minutes later and it ran on the 'pad.
My guess updates killed it. Updates also make my music disappear and have to reload from the cloud.
My guess on this, Verizon gets to charge freight every time so a bigger memory won't help if the firmware dumps it on purpose.
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 09-09-2018, 12:44 PM   #8
marter's Avatar
Lincoln , Nebraska
Hi
I meant all parasitic loads, not the MPPT. I dont have a switch so I disconnect the neg cables when I store.
I can't disconnect the solar, didn't bring the right socket. Have to try it when I get home.
Mike
Old 09-09-2018, 12:47 PM   #9
marter's Avatar
Lincoln , Nebraska
Possible, my android did an update recently. If so, odd that I still connect to the battery monitor, just not the solar controller. No other bluetooth devices with me. I'll try the reset Uncle Bob suggested when I can.
Thanks for the reply,
Mike
Old 09-09-2018, 09:59 PM   #10
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Turn your mppt controller on and off, or shut the panels off for a second. Then retry. Sometimes in the morning when the sun comes up the power is so low it wonít ďactivateĒ the Bluetooth. This happens when it is connected a specific way.
Mine does this every day. I can read it on the phone. Then sun goes down and no power, it goes off. Next morning it wonít read until I do a quick reset. There is a way to fix this. In my case itís moving the negative line from solar charger from BMS to another location.
The amsolar guys helped me figure it out. I may change it over the winter. It doesnít stop it from charging just connecting the Bluetooth
Troutboy
Troutboy is offline   Reply With Quote
Old 09-10-2018, 06:42 AM   #11
marter's Avatar
Lincoln , Nebraska
Thanks for the reply Troutboy. Sounds like I need to make a change in the wiring. My controller is under the front dinette seat and not real convenient to access.
When you say "turn the controller off" are you disconnecting the wires? Don't know if another way to turn it off and on unless you have a disconnect switch. And I don't really have a spot to mount one that's accessible. At least in my DW's view.
So your wiring solution is to move the neg battery wire going from the controller to the BMV shunt to another connection? Won't I lose solar input monitoring? Where are you planning to connect it?
While I have you, my understanding of the MPPT controller is that it's going off battery voltage only, not SOC. I'm not likely to add the GX or CCGX so would I gain anything by networking my Smartsolar MPPT and BMV-712 over bluetooth, like making the controller aware of SOC? May not make a difference in my simple setup.
Thanks again,
Mike
Old 09-10-2018, 08:28 AM   #12
Troutboy's Avatar
Parker , Colorado
Mike. The way I turn off my controller is by flipping a switch I have from the solar panels. I had a disconnect switch to allow me to disconnect the solar panels from the system if needed.
I was told by am solar to switch the negative connection from the output side of BMS to input side. Iíll double check, and confirm. I need to find the email from them.
Mine is also hard to get to so I just decided to leave it.
So every morning, I flip that disconnect switch. Turn it off for a few seconds, and then in, and I get the Bluetooth monitoring.
Iím not sure about connecting or bridging with the BMV.
Troutboy
Old 09-10-2018, 08:43 AM   #13
marter's Avatar
Lincoln , Nebraska
Thanks. I may opt for the switch and hide it as best I can. Did you use a Blue Sea rotary switch?
Thanks again,
Mike
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
Old 09-10-2018, 09:00 AM   #14
Troutboy's Avatar
Parker , Colorado
Yes. I used a 4 way blue sea. I needed this as I wanted to be able to have the following positions:
1. Off
2. Roof solar only
3. Portable solar only
4. Roof and portable combined.
I am providing a link below to where I documented my solar install. Itís very long now with comments and such. It does provide pictures and diagrams of how I did my system if interested.
http://www.airforums.com/forums/f382...-a-162955.html
Troutboy
Battery doesn't charge without disconnect / reconnect of shore power WineStream Batteries, Univolts, Converters & Inverters 5 03-26-2013 06:32 PM
Unable to Winterize this year; advice for the thaw! Toronto_Guy Winterizing, Storage, Carports & Covers 36 01-03-2011 10:51 AM
Unable to Fill Fresh Water Tank forthefew Fresh Water Systems 3 09-06-2010 07:16 PM
Unable to view members photos.. Happycampers Forum Admin, News and Member Account Info 2 01-04-2004 12:26 AM
